Arduino Forum Question:What is the difference between Raspberry pi and Arduino?
  • Subscribers 418 subscribers
  • Views 498 views
Hello guys I'm a newbie I just want to know what's the difference b/w Raspberry pi and Arduino? thanks guys image
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +1
    Raspberry PI is a microprocessor based Linux single board computer with built in Ethernet, USB, HDMI Video, Audio, SD Card reader etc. It is a great place to start if your on a budget and want to learn…
  • vish
    0 vish over 12 years ago
    Hope this will help you : https://www.youtube.com/watch?v=7vhvnaWUZjE
    0 Robert Peter Oakes over 12 years ago
    Raspberry PI is a microprocessor based Linux single board computer with built in Ethernet, USB, HDMI Video, Audio, SD Card reader etc. It is a great place to start if your on a budget and want to learn about programming in various languages and have a dip into some level of controlling LEDs, Relays and other devices. It is great to create a Master Controller, a music player, a XBC / Home media center system etc
    An Arduino is an eco system of quite a range of different micro-controller boards, that started with ATMEL 8 Bit chips but has now extended to quite a range of devices including very powerful ARM Cortex microcontrollers, it would be remiss of me not to also mention the Texas Instruments LAUNCH PAD series of boards too as these are also great microcontroller boards with equally good capabilities as the Arduino boards. It depends on if you like green or Red image
    A microprocessor as found in the RPI s not so good at industrial control, driving Stepper motors, NEO Pixel LED lights or other devices that require critical timing. A Microcontroller is much better for those tasks and often will be used as a slave to a Raspberry PI or similar LINUX based machine to allow the PI to be the Brains and the Arduino / Launch pad to be the brawn
    If you want to start out leaning how to control things like lights, relays, motors etc. then start with the launch pad or an Arduino, If your more interested in the software side of things and want some flexibility in what language you use, want a full GUI based environment right one the device, go with the PI. Either way I think ultimately you will end up with both the PI and a microcontroller
    have a look here
    https://estore.ti.com/Launchpads-C194.aspx
    and
    http://arduino.cc/en/Main/Products
    and
    http://www.raspberrypi.org/
    happy hunting
    Peter
  • neilk
    0 neilk over 12 years ago in reply to Robert Peter Oakes
    A very succinct differentiation between the Pi and the Arduino.
    Thanks Peter - probably the best I've read!
    Neil
    Guys thank you for your reply guys now I understand image
