    • Avnet Boards Community
Arduino Forum I am trying to figure out how to write a code that explains the queuing of a 2 way intersection with stop signs. Explain with leds who has the right away green means go red means wait
  • Subscribers 393 subscribers
  • Views 385 views
Use ir sensors to detect an object which would be the car. So 2 sensors and 4leds
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to Former Member +1
    Fairly easy to use a simple state machine and a switch - case, if it where longer I would look at it differently but this is a pretty short and simple thing
    0 Robert Peter Oakes over 10 years ago
    Sounds about right to me, very simple and effective
    Sent from my iPhone
    0 Former Member over 10 years ago in reply to Robert Peter Oakes
    Do you have any ideas whether to use an array, or switch case, or else/if??
    0 Robert Peter Oakes over 10 years ago in reply to Former Member
  • D_Hersey
    0 D_Hersey over 10 years ago
    But if you wanted to put out a little more effort into it you could have car objects with member functions such as look_left(), look_right(), check_intersection().  Then you could set up the instantiations with their own theads.  You could then use tick-time to model slow-pokes and hotheads.  That would be interesting. . .
  • D_Hersey
    Let me suggest you consider hall-effect sensing rather than optical interruption here.  It could be both more reliable and unobtrusive, maybe.  Probably easier to implement.  Perhaps you could glue PMs to the bottom of your model cars.
    Though, maybe you could glue a mirror to the bottom of a car just as easily. . .
    This is juicy.  Please elaborate a little more upon your application, SVP.
    Did you figure it out yet?
