Arduino Forum First project ever and need help!
  • Replies 25 replies
  • Subscribers 416 subscribers
  • Views 2651 views
  • help
  • first_project
  • ben_heck
  • question
     To start i'm 15 and this is my first project that I have sat down and actually planned out. Also please note I have little to no programming skills. My plan is to build a vending machine that is powered by an arduino board. The arduino would power servo motors that would then dispense the item. My question is where do I even start. What kind of motors should I get? Can the arduino even run several motors? How can I make this connectable to an outlet? (not battery powered). What equipment do I need? I have so many questions I could write book. Any design tips and help I can get would be great. Also any design changes you think would make the idea more efficient do share.Thanks.
  • gadget.iom
    gadget.iom over 11 years ago in reply to e14 Contributor +1
    A good way to do this would be to use a DC motor that will rotate at a fixed speed. You can then control that using your arduino while timing a 360 operation and/or using a optical sensor to detect a complete…
  • gadget.iom
    gadget.iom over 11 years ago in reply to gadget.iom +1
    As this post looks like it is going to be mostly Arduino based you may want to move this post to The specified item was not found. . You can do this by clicking 'Move' in the menu on the right.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    Voltage regulators possibly, depending on the supply voltage and the voltage of your peripheral components (motors etc). Transistors, almost certainly. image
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    So from my understanding so far when I click the button it will be hooked up to the arudino which will then tell a dc motor to spin a full 360 degrees then stop?
  • gadget.iom
    Put simply... yes image
  • gadget.iom
    And you can repeat this x number of times.
    Thanks so much! Now I have a lot to go off of. I was taking notes image
  • gadget.iom
    Good to know. Keep us updated on your progress. image
  • gadget.iom
    Another aspect to look at (though possibly a little more complete to wire up) is Stepper Motors. You can instruct them to rotate by a stated number of degrees. You can issue a command to rotate by 360º. Optical sensing would therefore only be necessary for error detection.
    Would 5 of these work? And what is a driver board? is it necessary?
    Amazon.com: RioRand Stepper Motor 5V DC 4-Phase 5-Wire with ULN2003 Driver Board: Computers & Accessories
  • gadget.iom
    Those stepper motors appear to be supplied with the necessary diver board. You will need 4 digital outputs per motor to drive these.
    My only concern is wether they have enough torque to turn the coil and drag the goodies along the track in your machine.
    I had a feeling the torque would be low this doesn't have a driver board but does have high torque
    1700-7300RPM 1.5-6.5V High Torque Cylinder Electric Mini DC Motor - Electric Fan Motors - Amazon.com
