Arduino Forum Powering a Yun
  • Replies 7 replies
  • Subscribers 417 subscribers
  • Views 1305 views
  • yun
  • ardunio
  • powering
  • question
Powering a Yun
markvenn
markvenn over 11 years ago
Hi all
Question for you all regarding the powering of an Arduino Yun. As it is not like the Uno or Mega ADK in that is does not take a range of voltages and seems to be expecting a nice 5V usb supply, if I want to set one up as a standalone bit of kit can I supply power via 1.5V cells 3 x 1.5 = 4.5V? I see that I should be able to power using PoE but I was wondering if I could use it wifi only for some project ideas. I sort of think that 4.5V is not going to be good enough and I don't really want to stick 6V in as this is too much and the web page Arduino - ArduinoBoardYun seems to say that the 5V is the absolute limit. Does anyone have experience with battery powered Yun?
Cheers
  • gadget.iom
    gadget.iom over 11 years ago +1
    Something like this might work for you: 3A UBEC for Raspberry Pi - Dawn Robotics
  • gadget.iom
    0 gadget.iom over 11 years ago
  • markvenn
    0 markvenn over 11 years ago in reply to gadget.iom
    Hey Paul
    This looks like a perfect solution for me. Of course it is perfect for the Pi so I think a couple of these may need to be ordered shortly!
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    Go for more volts then use an inexpensive and efficient buck convertor to drop the volts to 5V (6 1.5V cells or a pair of LIPO would work ) with little loss of power due to the regulation process, using a LDO linear regulator is also an option but you will waste a significant amount of your available power as heat dissipation in the regulator
    My assumption is the 1.%V cells are alkaline, not re-chargeable NIMH as the volts for those re different
    Btw, if you use NIMH re-chargeablea, as there nearer 1.2V, not 1.5 you can use four of those to make 4.8V ish, much better to use without a regulator
    http://en.wikipedia.org/wiki/Nickel%E2%80%93metal_hydride_battery
    hope this helps
    Peter
  • clem57
    0 clem57 over 11 years ago
    I did a little research @Mark Venn  and can tell you the Linux side only needs 3.3V to operate. So not a problem here for a drop of .5V. The ATmega32u4 though would rather have a full 5 V. If you slow down the processor from 16 Mhz to only 8 Mhz, the requirement is cut in half to 3.0. This can be done carefully by changing the correct Fuse(soft programming) to use an internal oscillator at 8 Mhz. Be warned that incorrectly changing them can be fatal to the ATmega32u4 leaving you with no replacement since it is SMT mount and not DIPimage
    Clem
    The calibrated internal RC Oscillator by default provides a 8.0 MHz clock. This frequency is nominal value at 3V and 25°C. See datasheet.
    0 Robert Peter Oakes over 11 years ago in reply to clem57
    You can change the 32U4 if needed, its just a little more tricky, I have an article on that very subject
    See here: http://www.thebreadboard.ca/?cat=19
    Sorry I don’t think I have this posted on the E14 site
    So it is not always a disaster if the worst happens, just an opportunity to try something new image
    Peter
  • clem57
    0 clem57 over 11 years ago in reply to Robert Peter Oakes
    @Peter Oakes,
         Based on my recent experiences, this looks like brain surgery(LOL) by a kid(Me).image BTW, I like your site!
    Clem
    The essential part is the hot air re-flow soldering Iron, eBay special for under 100$
    solder paste helps too vs thin solder but that post was with regular solder as I had no paste at the time
    Oh, and a magnifier, my eyes are not what they used to be image
