    • Avnet Boards Community
Arduino Forum How to Sequentially Activate Pins while Reading from a Sensor ?
  • Replies 8 replies
  • Subscribers 392 subscribers
  • Views 559 views
aureta
aureta over 10 years ago
Hi, I am starting with Arduino and I am in need of some help. I am trying to sequentially activate 5 pins. I need each pin to be active for 20 seconds in a PWM manner. During their active period I want an arduino sensor to constantly read out the signals emmited by each pin effector. So far I have no problems with the PWM or sensing module code. However I am not able to find how to correctly sequentially activate the pins. I used millis(), etc, but so far I was able to only activate / read the signals from the first pin effector. The sketch doesn´t proceed to the 2nd --- pins. I really very much appreciate your help ....
  • dtsartsanis
    dtsartsanis over 10 years ago +1
    If you post your code someone will help you
    balearicdynamics over 10 years ago in reply to aureta +1
    Hello, your mistake is in the use of millis() With this function you get the number of milliseconds occured from the last power-on of the microcontroller . So you should not put while(millis()<5000) because…
  • dtsartsanis
    0 dtsartsanis over 10 years ago
    If you post your code someone will help youimage
    0 balearicdynamics over 10 years ago
    Hello Alejandro,
    please post your code or at least your idea of code architecture. Anyway the better solution I see is to use a timer interrupt or a bare interrupt but in this case you have a pin locked by the interrupt trigger. Take in account that using this tecnique you can't use the delay() or millis() count anymore. In many cases I have used millis() that is efficient as it will work in a very similar way as software interrupt. Without your code I think it is really impossible to give you a more detailed advice.
  • aureta
    0 aureta over 10 years ago in reply to dtsartsanis
    Hi Dimitros, here´s the code so far...
    const int greenPin = 11;
    const int redPin = 10;
    const int irPin = 5;
    const int bluePin = 6;
    const int yellowPin = 9;
    const int outputLDR = 12;
    const int ldrSensor = A0;
    int brightness = 0;
    int increment = 1;
    int readingoutputLDR = 0;
    void setup()
      pinMode(greenPin, OUTPUT);
      pinMode(redPin, OUTPUT);
      pinMode(irPin, OUTPUT);
      pinMode(bluePin, OUTPUT);
      pinMode(yellowPin, OUTPUT);
      Serial.begin(9600);
      setup_parallax();
    void loop()
    digitalWrite(outputLDR, HIGH);
    readingoutputLDR = analogRead(ldrSensor);
    while (millis()<5000)
                       if(brightness > 255)
                        increment = -1; // count down after reaching 255
                       else if(brightness < 1)
                       increment = 1; // count up after dropping back down to 0
                       brightness = brightness + increment;
                       analogWrite(greenPin, brightness); digitalWrite(redPin, LOW); digitalWrite(irPin, LOW);
                       digitalWrite(bluePin, LOW); digitalWrite(yellowPin, LOW);
                       Serial.print("Reading Green"); parallax_output();
    delay(1);
                       delay(1);
                       digitalWrite(greenPin, LOW); analogWrite(redPin, brightness); digitalWrite(irPin, LOW);
                      Serial.print("Reading Red"); parallax_output();
                       delay(1);
                       digitalWrite(greenPin, LOW); digitalWrite(redPin, LOW); analogWrite(irPin, brightness);
                        Serial.print("Reading IR"); parallax_output();
                       delay(1);
                       digitalWrite(greenPin, LOW); digitalWrite(redPin, LOW); digitalWrite(irPin, LOW);
                       analogWrite(bluePin, brightness); digitalWrite(yellowPin, LOW);
                       Serial.print("Reading Blue"); parallax_output();
                       delay(1);
                       digitalWrite(greenPin, LOW); digitalWrite(redPin, LOW); digitalWrite(irPin, LOW); digitalWrite(bluePin, LOW);                   analogWrite(yellowPin, brightness);
                      Serial.print("Reading Yellow"); parallax_output();
    void parallax_output()
                       Serial.print("DATA,DATE,TIME,");
                       Serial.println(readingoutputLDR);
    void setup_parallax()
        Serial.println("CLEARDATA");
        Serial.println("LABEL,Date,Time,Green Response, Red Response, IR Response, Blue Response, Yellow Response");
    0 balearicdynamics over 10 years ago in reply to aureta
    your mistake is in the use of millis() With this function you get the number of milliseconds occured from the last power-on of the microcontroller. So you should not put while(millis()<5000) because it occurs only one time, before the first 5 seconds the program run! Try something like this
    int myTime = 0; // The time delay counter
    int eventCounter = 0; // The event counter you need
    void setup() {
    // your stuff
    myTime = millis(); // init the time counter
    eventCounter = 1; // start first event
    void loop() {
    // Check if 5 seconds has passed
    if( (millis() - myTime) > 5000) ) {
         // Process the current event
         switch(eventCounter) {
              case 1: // event 1
                   // your stuff for event 1
                  eventCounter++; // next event ...
                  myTime = millis(); // reset the time counter
              break;
              case 2: // event 2
                   // your stuff for event 2
              break;
              case 3: // event 3
                   // your stuff for event 3
              break;
              // And so on... for all the events you need to manage in sequence every 5 seconds
              // Then, the last event, as you should restart to the first event
              case 5: // event 5, the last
                   // your stuff for event 5
                   eventCounter = 1; // next time restart to the first event
              break;
         } // end event processing
    } // every 5 seconds
  • aureta
    0 aureta over 10 years ago in reply to balearicdynamics
    Hi Enrico, thanks a lot for your help. I modified the code but seems there are compilation problems that I can´t see. I am att below the modified code, I will appreciate very much if you can take a look at it, Alex.
    int brightness = 0;
    int increment = 1;
    void setup()
      Serial.begin(9600);
      setup_parallax();
    void loop()
    if ((millis()- myTime) > 5000))
                              case 1: // event 1
                   break;
                              case 2: // event 2
                    break;
              case 3: // event 3
                       else if (brightness < 1)
              break;
              case 4: // event 4
                   // your stuff for event 4
              break;
                       analogWrite(yellowPin, brightness); Serial.print("Reading Yellow"); parallax_output();
              break;
    Line 37 - removed an extra ')'
    Correct as follows:
    if ( (millis()- myTime) > 5000)
    That's all. Then compile.
    Regards.
  • aureta
    Right, LEDs are glowing. There´s a problem though, my intention is that each pin or led should be continuosly active for at least five seconds in a PWM manner. During this time I want to read the effect on a LDR, I need LDR response curves to LED lights. In this modified sketch, the pins are sequentially activated for 5 sec but the PWM increase is seen only after successive cycles (next activation step for each LED). Seems that it goes all  through the code before changing LED intensity levels. ..... If you can help me with this (I really need it) I will be extremely happy.  Alex
  • aureta
    0 aureta over 10 years ago in reply to aureta
    I´ve got it working, i kept the original while millis() statements but included windows of time for during which each pin should be activated. ....
