    • Avnet Boards Community
Arduino Forum problem pairing xbee series 1 by puTTy
  • Subscribers 392 subscribers
  • Views 495 views
Okay, so i just wanted to pair 2 Xbees modules of Series 1 by using puTTY software.
The commands that i should have used were :
For first xbee
+++                    *wait for an OK*
ATMY1000       *ENTER*
ATDL1001.       *ENTER*
ATID1111         *COMMA*
WR                     *ENTER*
For second xbee
ATMY1001       *ENTER*
ATDL1000        *ENTER*
ATID1111         *COMMA*
WR                     *ENTER*
By mistake, it wrote :
For first xbee
ATMY1000       *ENTER*
ATDL1001        *ENTER*
ATID1111         *COMMA*
WR                     *ENTER*
For second xbee
ATMY1001       *ENTER*
ATDL1000        *ENTER*
ATID1111         *ENTER*
ATMY1001       *ENTER*
ATDL1000        *ENTER*
ATID1111         *COMMA*
WR                     *ENTER*
I started with +++ again for second xbee 'coz i had to type a *comma* instead of *enter* but i did'nt write that time.
So my question is whether it would work or not. Also, what should i do to re-configure them?
  • fvan
    0 fvan over 10 years ago
    Could you be clearer on what you are trying to do, what you did instead and what you tried afterwards ?
    It's hard for people to help if the question and situation are not clear.
    Edit: thanks for updating your post.
  • clem57
    0 clem57 over 10 years ago
    anujdawar
    Easy enough to follow and tell where things go wrong: Arduino Wireless Programming with XBee Series 1 or 2
  • clem57
    I checked you are ok so long as you do not WR. The WR commits the values to EEPROM. BTW, you can reconfigure them again if needed.
    Clem
    0 Former Member over 10 years ago in reply to clem57
    Now that i've WR the IDs, can i normally re-configure them? Just by starting with +++ ? Like, if i want to change the IDs, won't i need any command to delete the existing IDs? Or would it just normally overwrite over the existing ones? Would it work fine?
  • clem57
    0 clem57 over 10 years ago in reply to Former Member
    Yes. The WR allows them to remember after a power cut. Otherwise they would forget and revert to the last WR.
    Clem
    That was very helpful. Thanks.. Btw what's the use of ATCN command? Isn't it necessary?
