Arduino Forum Sending serial data from Arduino to Android via Bluetooth - NOT ANSWERED Yet
  • Replies 23 replies
  • Answers 7 answers
  • Subscribers 420 subscribers
  • Views 8027 views
  • bluetooth
Hi all,
I've been working on my Arduino project for quite a while now, managed to process the incoming data in the Arduino and display it on LCD (data is coming from a simulation on the laptop). But I cannot manage to view this data on my Android App (used MIT App Inventor) via Bluetooth (HC-06). I have managed to do this but after a week I tested it again and found some errors (I think problem was with my hardware) therefore (silly me) I didnt save the sketch, therefore blocks in MIT App Inventor are 100% working.
Also, I am connecting RX pin of Bluetooth through a voltage divider with pin 7.  Any ideas pls?
Arduino sketch:
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
byte myByte; // Storing the incoming data from serial port
int txPin = 7;
int rxPin =6;
lcd(12,11,5,4,3,2) //pin of lcd   ****I know this is not the exact command
SoftwareSerial BlueToothConnect(txPin, rxPin);
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
void setup(){
lcd.begin(16,2);
Serial.begin(9600);  //Serial communication
void loop(){
if(Serial.available(){
lcd.clear();
while(Serial.available()>0){       //Until data is being found in Serial, turn on serial on Bluetooth
BlueToothConnect.begin(9600);
myByte = Serial.read(); //reading the myByte data
lcd.write(myByte);  //showing data on LCD
Serial.write(myByte) ; //Showing data on serial monitor
txPin = digitalWrite(myByte);   //writing myByte content on pin 7 (txPin)
BlueToothConnect.write(txPin);   //  BlueToothConnect.print(txPin);  //displaying content of txPin to be view on Android display
Message was edited by: Lor B
  • neilk
    neilk over 11 years ago in reply to e14 Contributor +2 verified
    Hi lorrainebarbara I've never used SoftwareSerial successfully, although I've been trying to recently to reprogram an HC05 (Master/Slave Bluetooth). This requires the use of SoftWare serial ad so far I…
    e14 Contributor over 11 years ago in reply to neilk +2 suggested
    Hi neilk , Thank you so much I have managed to incorporate (and change) some of the program you ve published, worked Here is my whole sketch. Thanks alot for your help!! //Sending data serially to Android…
  • gadget.iom
    gadget.iom over 8 years ago in reply to happyforever +2 suggested
    Are you trying to send sensor values or text typed into the serial monitor? All of the other references to bluetooth.print are commented out. Try putting: bluetooth.print("Sending Init String"); // Test…
  • talesdg
    0 talesdg over 9 years ago in reply to neilk
    hi, i'm trying to print on my android cellphone but i dont have the right app, where can i find your android app for download?
  • neilk
    0 neilk over 9 years ago in reply to talesdg
    Hi talesdg
    You can find it here:
    https://www.element14.com/community/people/neilk/blog/2014/07/18/app-inventor-and-arduino-part-2--send-data-from-arduino-to-android-app
    Hope this helps.
    Neil
  • dssen
    0 dssen over 9 years ago in reply to neilk
    Can ypu give me the link of your blog to Android app
  • neilk
    0 neilk over 9 years ago in reply to dssen
    Hi dssen
    You can find the link to my blog in the previous post.
    Neil
  • happyforever
    0 happyforever over 8 years ago
    I can receive data from android but cant send data to android, please help me to solve. The below is my code.
    int bluetoothTx = 13;  // TX-O pin of bluetooth mate, Arduino D2
    int bluetoothRx = 14;  // RX-I pin of bluetooth mate, Arduino D3
    char incomingByte; // incoming data
    int sensorPin = A0;
    int ledPin = 11;      // select the pin for the LED
    int ledPin2 = 12;
    int sensorValue = 0;  // variable to store the value coming from the sensor
    int rTrigPin = 6;
    int rEchoPin = 7;
    int trigPin = 9;
    int echoPin = 10;
    int lTrigPin = 4;
    int lEchoPin = 5;
    // defines variables
    long rDuration;
    int rDistance;
    long duration;
    int distance;
    long lDuration;
    int lDistance;
    SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
    void setup() {
      Serial.begin(115200);
      bluetooth.begin(115200);  // The Bluetooth Mate defaults to 115200bps
      //bluetooth.print("$");  // Print three times individually
      //bluetooth.print("$");  // Enter command mode
      //delay(100);  // Short delay, wait for the Mate to send back CMD
      //bluetooth.println("U,9600,N");  // Temporarily Change the baudrate to 9600, no parity
      // 115200 can be too fast at times for NewSoftSerial to relay the data reliably
      bluetooth.begin(9600);  // Start bluetooth serial at 9600
      pinMode(rTrigPin, OUTPUT); // Sets the rTrigPin as an Output
      pinMode(rEchoPin, INPUT); // Sets the rEchoPin as an Input
      pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
      pinMode(echoPin, INPUT); // Sets the echoPin as an Input
      pinMode(lTrigPin, OUTPUT); // Sets the lTrigPin as an Output
      pinMode(lEchoPin, INPUT); // Sets the lEchoPin as an Input
      // declare the ledPin as an OUTPUT:
      pinMode(ledPin, OUTPUT);
      pinMode(ledPin2, OUTPUT);
    /*void loop() {
      // read the value from the sensor:
      sensorValue = analogRead(sensorPin);
      // turn the ledPin on
      digitalWrite(ledPin, LOW);
      // stop the program for <sensorValue> milliseconds:
      delay(sensorValue);
      // turn the ledPin off:
      digitalWrite(ledPin, HIGH);
      // stop the program for for <sensorValue> milliseconds:
      delay(sensorValue);
    void loop()
            digitalWrite(rTrigPin, LOW);
            delayMicroseconds(2);
            digitalWrite(rTrigPin, HIGH);
            delayMicroseconds(10);
            rDuration = pulseIn(rEchoPin, HIGH);
            rDistance = (rDuration / 2) / 29.1;
            digitalWrite(trigPin, LOW);
            digitalWrite(trigPin, HIGH);
            duration = pulseIn(echoPin, HIGH);
            distance = (duration / 2) / 29.1;
            digitalWrite(lTrigPin, LOW);
            digitalWrite(lTrigPin, HIGH);
            lDuration = pulseIn(lEchoPin, HIGH);
            lDistance = (lDuration / 2) / 29.1;
              if (rDistance <= 221 || distance <= 221 || lDistance <= 221)
              if (sensorValue <= 140)
                digitalWrite(ledPin2, LOW);
              else
                digitalWrite(ledPin2, HIGH);
            else if (rDistance > 221 || distance > 221 || lDistance > 221)
              else
      if (bluetooth.available()) // If the bluetooth sent any characters
        // Send any characters the bluetooth prints to the serial monitor
        Serial.println((char)bluetooth.read());
        incomingByte = bluetooth.read();
        if(incomingByte == '1') {
             Serial.println("Music is pause and now you are in dangerous situation.");  // print message
             //bluetooth.print("1");
             //delay(1000);
        if(incomingByte == '0') {
              Serial.println("Alert signal OFF and music would not pause when in dangerous situation.");  // print message
              //bluetooth.print("0");
              //delay(1000);
              //break;
      if (Serial.available()>0) // If stuff was typed in the serial monitor
        int bytes=Serial.available();
        //Serial.readBytes(buffer, startPosition, bytes);
        bluetooth.print((char)Serial.read());
  • gadget.iom
    0 gadget.iom over 8 years ago in reply to happyforever
    Try putting:
    bluetooth.print("Sending Init String"); // Test bluetooth TX
    after the line:
    and see if you get any output when you reset the Arduino.
  • neilk
    0 neilk over 8 years ago in reply to happyforever
    Hi happyforever I have replied to you as well, but at the other location. I was already composing my reply there when mcb1 replied here.
    Neil
  • happyforever
    0 happyforever over 8 years ago in reply to gadget.iom
    Thanks for reply my answer, but i try add the [ bluetooth.print("Sending Init String"); ] but the error still there. Besides that, serial monitor also do not display this message.
    Is because android part got problem? Below is my android code(MainActivity.java)
    package com.example.helloworld.ninjatechsmartheadphone;
    import java.io.IOException;
    import java.io.InputStream;
    import java.io.OutputStream;
    import java.lang.reflect.Method;
    import java.util.UUID;
    import android.support.v7.app.AppCompatActivity;
    import android.bluetooth.BluetoothAdapter;
    import android.bluetooth.BluetoothDevice;
    import android.bluetooth.BluetoothSocket;
    import android.content.Intent;
    import android.os.Bundle;
    import android.os.Handler;
    import android.util.Log;
    import android.view.View;
    import android.view.View.OnClickListener;
    import android.widget.Button;
    import android.widget.TextView;
    import android.media.MediaPlayer;
    import android.widget.Toast;
    public class MainActivity extends AppCompatActivity {
       private static final String TAG = "bluetooth";
       Button on;
       Button off;
       Button button;
       TextView txtArduino;
       Handler h;
      final int RECIEVE_MESSAGE = 1;  // Status for Handler
       private BluetoothAdapter btAdapter = null;
      private BluetoothSocket btSocket = null;
      private StringBuilder sb = new StringBuilder();
      private ConnectedThread mConnectedThread;
       // SPP UUID service
       private static final UUID MY_UUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB");
      private static String address = "98:D3:31:FD:21:00";
       @Override
       public void onCreate(Bundle savedInstanceState) {
       super.onCreate(savedInstanceState);
       setContentView(R.layout.activity_main);
      final MediaPlayer catSoundMediaPlayer = MediaPlayer.create(this, R.raw.afi);
       button = (Button) findViewById(R.id.play);
       on = (Button) findViewById(R.id.on);
       off = (Button) findViewById(R.id.off);
       txtArduino = (TextView) findViewById(R.id.txtArduino);  // for display the received data from the Arduino
       h = new Handler() {
       public void handleMessage(android.os.Message msg) {
      Log.d("msg", "msg.what is " + msg.what);
      switch (msg.what) {
       case RECIEVE_MESSAGE:  // if receive massage
       byte[] readBuf = (byte[]) msg.obj;
       Toast.makeText(getBaseContext(), "I want try try try", Toast.LENGTH_SHORT).show();
       String strIncom = new String(readBuf, 0, msg.arg1);  // create string from bytes array
       sb.append(strIncom);  // append string
       int endOfLineIndex = sb.indexOf("\r\n");  // determine the end-of-line
       if (endOfLineIndex > 0) {  // if end-of-line,
       String sbprint = sb.substring(0, endOfLineIndex);  // extract string
       sb.delete(0, sb.length());  // and clear
       txtArduino.setText("Data from Arduino: " + sbprint);  // update TextView
      //off.setEnabled(true);
      // on.setEnabled(true);
      Log.d(TAG, "...String:"+ sb.toString() +  "Byte:" + msg.arg1 + "...");
      break;
      default:
      Toast.makeText(getBaseContext(), "I want try", Toast.LENGTH_LONG).show();
       btAdapter = BluetoothAdapter.getDefaultAdapter();  // get Bluetooth adapter
       checkBTState();
       button.setOnClickListener(new OnClickListener() {
       public void onClick(View v) {
       catSoundMediaPlayer.start();
       //Intent intent = new Intent("android.intent.action.MUSIC_PLAYER");
      //intent.addFlags(Intent.FLAG_ACTIVITY_NEW_TASK);
      //startActivity(intent);
       //on.setEnabled(false);
       mConnectedThread.write("1");  // Send "1" via Bluetooth
       Toast.makeText(getBaseContext(), "Turn on Alert Signal", Toast.LENGTH_SHORT).show();
       off.setOnClickListener(new OnClickListener() {
       //off.setEnabled(false);
       mConnectedThread.write("0");  // Send "0" via Bluetooth
       Toast.makeText(getBaseContext(), "Turn off Alert Signal", Toast.LENGTH_SHORT).show();
       private BluetoothSocket createBluetoothSocket(BluetoothDevice device) throws IOException {
       try {
       final Method m = device.getClass().getMethod("createInsecureRfcommSocketToServiceRecord", new Class[] { UUID.class });
      return (BluetoothSocket) m.invoke(device, MY_UUID);
       } catch (Exception e) {
      Log.e(TAG, "Could not create Insecure RFComm Connection",e);
       return  device.createRfcommSocketToServiceRecord(MY_UUID);
       @Override
       public void onResume() {
       super.onResume();
       Log.d(TAG, "...onResume - try connect...");
       // Set up a pointer to the remote node using it's address.
       BluetoothDevice device = btAdapter.getRemoteDevice(address);
       // Two things are needed to make a connection:
      // A MAC address, which we got above.
      // A Service ID or UUID. In this case we are using the
      // UUID for SPP.
       try {
       btSocket = createBluetoothSocket(device);
       } catch (IOException e) {
      errorExit("Fatal Error", "In onResume() and socket create failed: " + e.getMessage() + ".");
       // Discovery is resource intensive. Make sure it isn't going on
      // when you attempt to connect and pass your message.
       btAdapter.cancelDiscovery();
       // Establish the connection. This will block until it connects.
       Log.d(TAG, "...Connecting...");
      try {
       btSocket.connect();
       Log.d(TAG, "....Connection ok...");
       Toast.makeText(getBaseContext(), "Connected", Toast.LENGTH_SHORT).show();
       try {
       //Log.d(TAG, "....111...");
      //Toast.makeText(getBaseContext(), "1", Toast.LENGTH_SHORT).show();
       btSocket.close();
       } catch (IOException e2) {
      errorExit("Fatal Error", "In onResume() and unable to close socket during connection failure" + e2.getMessage() + ".");
       //Toast.makeText(getBaseContext(), "2", Toast.LENGTH_SHORT).show();
       // Create a data stream so we can talk to server.
       Log.d(TAG, "...Create Socket...");
       mConnectedThread = new ConnectedThread(btSocket);
       mConnectedThread.start();
       @Override
       public void onPause() {
       super.onPause();
       Log.d(TAG, "...In onPause()...");
      try  {
       btSocket.close();
      errorExit("Fatal Error", "In onPause() and failed to close socket." + e2.getMessage() + ".");
       private void checkBTState() {
       // Check for Bluetooth support and then check to make sure it is turned on
      // Emulator doesn't support Bluetooth and will return null
       if(btAdapter==null) {
      errorExit("Fatal Error", "Bluetooth not support");
       } else {
       if (btAdapter.isEnabled()) {
      Log.d(TAG, "...Bluetooth ON...");
       } else {
       //Prompt user to turn on Bluetooth
       Intent enableBtIntent = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
       startActivityForResult(enableBtIntent, 1);
       private void errorExit(String title, String message){
      Toast.makeText(getBaseContext(), title + " - " + message, Toast.LENGTH_LONG).show();
       finish();
       private class ConnectedThread extends Thread {
       private final InputStream mmInStream;
      private final OutputStream mmOutStream;
      public ConnectedThread(BluetoothSocket socket) {
      InputStream tmpIn = null;
       OutputStream tmpOut = null;
       // Get the input and output streams, using temp objects because
      // member streams are final
       try {
      tmpIn = socket.getInputStream();
       tmpOut = socket.getOutputStream();
       } catch (IOException e) { }
       mmInStream = tmpIn;
       mmOutStream = tmpOut;
       public void run() {
       byte[] buffer = new byte[256];  // buffer store for the stream
       int bytes; // bytes returned from read()
      //Toast.makeText(getBaseContext(), "qqqqqqq", Toast.LENGTH_SHORT).show();
      // Keep listening to the InputStream until an exception occurs
       while (true) {
       try {
       // Read from the InputStream
       bytes = mmInStream.read(buffer);  // Get number of bytes and message in "buffer"
       h.obtainMessage(RECIEVE_MESSAGE, bytes, -1, buffer).sendToTarget();  // Send to message queue Handler
       Toast.makeText(getBaseContext(), "q111q", Toast.LENGTH_SHORT).show();
       //Toast.makeText(getBaseContext(), "qq222qq", Toast.LENGTH_SHORT).show();
       break;
       /* Call this from the main activity to send data to the remote device */
       public void write(String message) {
      Log.d(TAG, "...Data to send: " + message + "...");
      byte[] msgBuffer = message.getBytes();
      try {
       mmOutStream.write(msgBuffer);
      Log.d(TAG, "...Error data send: " + e.getMessage() + "...");
  • happyforever
    0 happyforever over 8 years ago in reply to neilk
    Hi Neil, can you help me check my android code got any problem? I think maybe is android part cause this error.
       Button on;
       Button off;
       Button button;
       Handler h;
       // SPP UUID service
       @Override
       h = new Handler() {
      switch (msg.what) {
      break;
      default:
       checkBTState();
       try {
       @Override
       super.onResume();
      // UUID for SPP.
       try {
      try {
       btSocket.connect();
       try {
       btSocket.close();
       @Override
       super.onPause();
      try  {
       btSocket.close();
       } else {
       } else {
       finish();
       try {
       mmInStream = tmpIn;
       public void run() {
       while (true) {
       try {
       break;
      try {
  • happyforever
    0 happyforever over 8 years ago in reply to happyforever
    I had debug the android code, found that the I cant run into the switch case. Can anyone help me to correct it? Thanks
       h = new Handler() {
      switch (msg.what) {
      break;
      default:
