Arduino Forum Sending serial data from Arduino to Android via Bluetooth - NOT ANSWERED Yet
  • Replies 23 replies
  • Answers 7 answers
  • Subscribers 420 subscribers
  • Views 8041 views
  • bluetooth
Hi all,
I've been working on my Arduino project for quite a while now, managed to process the incoming data in the Arduino and display it on LCD (data is coming from a simulation on the laptop). But I cannot manage to view this data on my Android App (used MIT App Inventor) via Bluetooth (HC-06). I have managed to do this but after a week I tested it again and found some errors (I think problem was with my hardware) therefore (silly me) I didnt save the sketch, therefore blocks in MIT App Inventor are 100% working.
Also, I am connecting RX pin of Bluetooth through a voltage divider with pin 7.  Any ideas pls?
Arduino sketch:
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
byte myByte; // Storing the incoming data from serial port
int txPin = 7;
int rxPin =6;
lcd(12,11,5,4,3,2) //pin of lcd   ****I know this is not the exact command
SoftwareSerial BlueToothConnect(txPin, rxPin);
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
void setup(){
lcd.begin(16,2);
Serial.begin(9600);  //Serial communication
void loop(){
if(Serial.available(){
lcd.clear();
while(Serial.available()>0){       //Until data is being found in Serial, turn on serial on Bluetooth
BlueToothConnect.begin(9600);
myByte = Serial.read(); //reading the myByte data
lcd.write(myByte);  //showing data on LCD
Serial.write(myByte) ; //Showing data on serial monitor
txPin = digitalWrite(myByte);   //writing myByte content on pin 7 (txPin)
BlueToothConnect.write(txPin);   //  BlueToothConnect.print(txPin);  //displaying content of txPin to be view on Android display
Message was edited by: Lor B
  • neilk
    neilk over 11 years ago in reply to e14 Contributor +2 verified
    Hi lorrainebarbara I've never used SoftwareSerial successfully, although I've been trying to recently to reprogram an HC05 (Master/Slave Bluetooth). This requires the use of SoftWare serial ad so far I…
    e14 Contributor over 11 years ago in reply to neilk +2 suggested
    Hi neilk , Thank you so much I have managed to incorporate (and change) some of the program you ve published, worked Here is my whole sketch. Thanks alot for your help!! //Sending data serially to Android…
  • gadget.iom
    gadget.iom over 8 years ago in reply to happyforever +2 suggested
    Are you trying to send sensor values or text typed into the serial monitor? All of the other references to bluetooth.print are commented out. Try putting: bluetooth.print("Sending Init String"); // Test…
  • neilk
    0 neilk over 8 years ago in reply to happyforever
    Sorry - I develop my android Apps at a much higher level using MIT Appinventor
  • sarath1210
    0 sarath1210 over 8 years ago
    hi neil i have configured my Bluetooth hc-05  it is pairing with android but i m not getting reply to my comments
  • neilk
    0 neilk over 8 years ago in reply to sarath1210
    Hi sarath1210
    It would be a good idea to post a new question, in the appropriate forum giving more details of your project.
    Neil
