Arduino Forum Best products to use for LED Matrix display for animations?
  • Subscribers 412 subscribers
  • Views 2438 views
pcmofo
pcmofo over 2 years ago
Hey all. I am working on making an animated Bender robot. I've built a prototype and it works well enough but I want to rethink my approach before continuing down my current path.
Early prototype (https://imgur.com/gallery/rERZgwm)
My current setup uses several microcontrollers to accomplish this. One controls the eyes/display. One plays audio files. And I planned on using a 3rd to animate the mouth
In an attempt to simplify my design for both the eyes and mouth I thought, what if both were LED arrays? I can worry about the exact size and custom 3D printed enclosure part later (what I have currently looks pretty good but I want to nail down the electronics better before investing any more time.
This is the general layout I was thinking of.
In both cases the mouth and eyes would use continuous array of LEDs These would at a minimum be single color LEDs but RGB, NeoPixel etc would all be acceptable as well. Since they are a display they would not need to be very bright individually.
Here is what I am hoping you can help me with
1. What combination of LED array types (charlie plex, multiplex, neopixel etc etc) and microcontroller processor etc would be the right fit here?
2. Does it still make sense to use multiple processors. in this case, one for each display, and most likely a 3rd to orchestrate/sync the animations between both displays and the audio, inputs etc.
Some additional info.
This is ultimately a custom clock/animated thing so cost is not a huge factor here.
I need or want it to be overly bright
Having an LED solution that works today and that I can build custom PCBs for later is a plus
Animations on the displays do not need to be crazy fast, just predictable in performance/timing and not crazy flickering.
I have the adafruit displays shown as well as a flexible neopixel array currently available to test with
I'm happy to buy a different microcontroller, currently using a M4 Express microcontroller.
Also happy to do this in Arduino or Circuit Python.
    dougw over 2 years ago +2
    It sounds like a great project. The Adafruit displays are nice. Here is an example: Epic Neopixel Birthday Cake -- Episode 583 The Arduino UNO R4 WiFi has an LED display that doesn't flicker, but…
    The Arduino UNO R4 WiFi has an LED display that doesn't flicker, but it may not have a suitable form factor:
     Arduino UNO R4 WiFi LED Demo
  • scottiebabe
    scottiebabe over 2 years ago
    There is a framebuffer library in micropython https://docs.micropython.org/en/latest/library/framebuf.html I'm sure the equivalent exists in circuitpython and Arduino, might be helpful
  • robogary
    robogary over 2 years ago
    Here are a couple examples using the MAX7219  LED matrix. My starting point was based on https://www.instructables.com/Animated-Halloween-Evil-Eyes/
    https://www.youtube.com/watch?v=9YOOgCp98c8
    Some projects definitely benefit using multiple Arduinos.
    There is a benefit to using qty 2 MAX7219 , one for each eye. The code can be the same for both eyes or can modify one eye's matrix to mirror the others for left and right.
    I always use a separate audio card like a WTV020 or DFPlayer so the project can be done in stages.
    https://www.youtube.com/watch?v=3ZCi0ro0LFc
    Here is the Arduino code from the animatronic gas mask
    // GasMaskMatrixEyesAndSoundWorks.ino
    //www.brainy-bits.com/.../
    // Pin 12 is connected to DIN, Pin 11 is connected to CS and Pin 10 is connected to CLK.
    #include "LedControl.h"
    LedControl lc=LedControl(12,10,11,2); // Pins: DIN,CLK,CS, # of Display connected
    #include <Wtv020sd16p.h>
    int resetPin = 2; // The pin number of the reset pin.
    int clockPin = 3; // The pin number of the clock pin.
    int dataPin = 4; // The pin number of the data pin.
    int busyPin = 5; // The pin number of the busy pin.
    Wtv020sd16p wtv020sd16p(resetPin,clockPin,dataPin,busyPin);
    unsigned long delayTime=200; // Delay between Frames
    // Put values in arrays
    byte invader1a[] =
    B00011000, // First frame of invader #1
    B00111100,
    B01111110,
    B11011011,
    B11111111,
    B00100100,
    B01011010,
    B10100101
    byte invader1b[] =
    B00011000, // Second frame of invader #1
    B00111100,
    B01111110,
    B11011011,
    B11111111,
    B00100100,
    B01011010,
    B01000010
    byte invader2a[] =
    B00100100, // First frame of invader #2
    B00100100,
    B01111110,
    B11011011,
    B11111111,
    B11111111,
    B10100101,
    B00100100
    byte invader2b[] =
    B00100100, // Second frame of invader #2
    B10100101,
    B11111111,
    B11011011,
    B11111111,
    B01111110,
    B00100100,
    B01000010
    byte LeftEye1[]=
    { // LeftEye1, 0
    B00111100,
    B01111110,
    B11111111,
    B11100111,
    B11100111,
    B11111111,
    B01111110,
    B00111100
    byte RightEye1[]=
    { // RightEye1, 1
    B00111100,
    B01111110,
    B11111111,
    B11100111,
    B11100111,
    B11111111,
    B01111110,
    B00111100
    byte LeftEye2[] =
    { // LeftEye2, 2
    B00000000,
    B00111100,
    B01111110,
    B01100110,
    B01100110,
    B01111110,
    B00111100,
    B00000000
    byte RightEye2[]=
    { // RightEye2, 3
    B00000000,
    B00111100,
    B01111110,
    B01100110,
    B01100110,
    B01111110,
    B00111100,
    B00000000
    byte LeftEye3[]=
    { // LeftEye3, 4
    B00000000,
    B00011000,
    B00111100,
    B00100100,
    B00100100,
    B00111100,
    B00011000,
    B00000000
    byte RightEye3[] =
    { // RightEye3, 5
    B00000000,
    B00011000,
    B00111100,
    B00100100,
    B00100100,
    B00111100,
    B00011000,
    B00000000
    byte LeftEye4[] =
    { // LeftEye4, 6
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000
    byte RightEye4[] =
    { // RightEye4, 7
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000
    byte LeftEye5[] =
    { // LeftEye5, 8
    B01111110,
    B10000001,
    B10000001,
    B10011001,
    B10011001,
    B10000001,
    B10000010,
    B01111100
    byte RightEye5[]=
    { // RightEye5, 9
    B01111100,
    B10000010,
    B10000001,
    B10011001,
    B10011001,
    B10000001,
    B10000001,
    B01111110
    byte LeftEye6[]=
    { // LeftEye6, 10
    B01111110,
    B10000001,
    B10000001,
    B10011001,
    B10011001,
    B10000010,
    B10000100,
    B01111000
    byte RightEye6[]=
    { // RightEye6, 11
    B01111000,
    B10000100,
    B10000010,
    B10011001,
    B10011001,
    B10000001,
    B10000001,
    B01111110
    byte LeftEye7[]=
    { // LeftEye7, 12
    B01111110,
    B11000001,
    B10000001,
    B10011001,
    B10011010,
    B10000100,
    B10001000,
    B01110000
    byte RightEye7[]=
    { // RightEye7, 13
    B01110000,
    B10001000,
    B10000100,
    B10011010,
    B10011001,
    B10000001,
    B11000001,
    B01111110
    byte LeftEye8[]=
    { // LeftEye8, 14
    B00111110,
    B01000001,
    B10000001,
    B10011001,
    B10011010,
    B10000100,
    B01001000,
    B00110000
    byte RightEye8[]=
    { // RightEye8, 15
    B00110000,
    B01001000,
    B10000100,
    B10011010,
    B10011001,
    B10000001,
    B01000001,
    B00111110
    byte LeftEye9[]=
    { // LeftEye9, 16
    B00111100,
    B01111110,
    B11111111,
    B11100111,
    B11100111,
    B11111111,
    B01111110,
    B00111100
    byte RightEye9[]=
    { // RightEye9, 17
    B00111100,
    B01111110,
    B11111111,
    B11100111,
    B11100111,
    B11111111,
    B01111110,
    B00111100
    byte LeftEye10[]=
    { // LeftEye10, 18
    B00111100,
    B01111110,
    B11111111,
    B11111111,
    B11111111,
    B11100111,
    B01100110,
    B00111100
    byte RightEye10[]=
    { // RightEye10, 19
    B00111100,
    B01111110,
    B11111111,
    B11111111,
    B11111111,
    B11100111,
    B01100110,
    B00111100
    byte LeftEye11[]=
    { // LeftEye11, 20
    B00111100,
    B01111110,
    B11111111,
    B11111001,
    B11111001,
    B11111111,
    B01111110,
    B00111100
    byte RightEye11[]=
    { // RightEye11, 21
    B00111100,
    B01111110,
    B11111111,
    B11111001,
    B11111001,
    B11111111,
    B01111110,
    B00111100
    byte LeftEye12[]=
    { // LeftEye12, 22
    B00111100,
    B01100110,
    B11100111,
    B11111111,
    B11111111,
    B11111111,
    B01111110,
    B00111100
    byte RightEye12[]=
    { // RightEye12, 23
    B00111100,
    B01100110,
    B11100111,
    B11111111,
    B11111111,
    B11111111,
    B01111110,
    B00111100
    byte LeftEye13[]=
    { // LeftEye13, 24
    B11000011,
    B10000001,
    B00000000,
    B00011000,
    B00011000,
    B00000000,
    B10000001,
    B11000011
    byte RightEye13[]=
    { // RightEye13, 25
    B11000011,
    B10000001,
    B00000000,
    B00011000,
    B00011000,
    B00000000,
    B10000001,
    B11000011
    byte LeftEye14[]=
    { // LeftEye14, 26
    B00111100,
    B01111110,
    B11111111,
    B10011111,
    B10011111,
    B11111111,
    B01111110,
    B00111100
    byte RightEye14[]=
    { // RightEye14, 27
    B00111100,
    B01111110,
    B11111111,
    B10011111,
    B10011111,
    B11111111,
    B01111110,
    B00111100
    byte LeftEye15[]=
    { // LeftEye15, 28
    B00000000,
    B00111100,
    B00100100,
    B00100100,
    B00100100,
    B00111100,
    B00111100,
    B00000000
    byte RightEye15[]=
    { // RightEye15, 29
    B00000000,
    B00111100,
    B00100100,
    B00100100,
    B00100100,
    B00111100,
    B00111100,
    B00000000
    byte LeftEye16[]=
    { // LeftEye16, 30
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00000000
    byte RightEye16[]=
    { // RightEye16, 31
    B00000000,
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00011000,
    B00011000
    byte LeftEye17[]=
    { // LeftEye17, 32
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000
    byte RightEye17[]=
    { // RightEye17, 33
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000,
    B00010000
    byte LeftEye18[]=
    { // LeftEye18, 34
    B00000000,
    B00000000,
    B00000000,
    B00011000,
    B00011000,
    B00000000,
    B00000000,
    B00000000
    byte RightEye18[]=
    { // RightEye18, 35
    B00000000,
    B00000000,
    B00000000,
    B00011000,
    B00011000,
    B00000000,
    B00000000,
    B00000000
    byte LeftEye19[]=
    { // LeftEye19, 36
    B00000000,
    B00000000,
    B00111100,
    B00100100,
    B00100100,
    B00111100,
    B00000000,
    B00000000
    byte RightEye19[]=
    { // RightEye19, 37
    B00000000,
    B00000000,
    B00111100,
    B00100100,
    B00100100,
    B00111100,
    B00000000,
    B00000000
    byte LeftEye20[]=
    { // LeftEye20, 38
    B00000000,
    B01111110,
    B01000010,
    B01000010,
    B01000010,
    B01000010,
    B01111110,
    B00000000
    byte RightEye20[]=
    { // RightEye20, 39
    B00000000,
    B01111110,
    B01000010,
    B01000010,
    B01000010,
    B01000010,
    B01111110,
    B00000000
    byte LeftEye21[]=
    { // LeftEye21, 40
    B00111110,
    B01000001,
    B10000001,
    B10011001,
    B10010010,
    B10000100,
    B01001000,
    B00110000
    byte RightEye21[]=
    { // RightEye21, 41
    B00110000,
    B01001000,
    B10000100,
    B10010010,
    B10011001,
    B10000001,
    B01000001,
    B00111110
    byte LeftEye22[]=
    { // LeftEye22, 42
    B11111111,
    B10000001,
    B10000001,
    B10011001,
    B10011001,
    B10000001,
    B10000001,
    B11111111
    byte RightEye22[]=
    { // RightEye22, 43
    B11111111,
    B10000001,
    B10000001,
    B10011001,
    B10011001,
    B10000001,
    B10000001,
    B11111111
    byte LeftEye23[]=
    { // LeftEye23, 44
    B00000000,
    B01111110,
    B01111110,
    B01100110,
    B01100110,
    B01111110,
    B01111110,
    B00000000
    byte RightEye23[]=
    { // RightEye23, 45
    B00000000,
    B01111110,
    B01111110,
    B01100110,
    B01100110,
    B01111110,
    B01111110,
    B00000000
    byte LeftEye24[]=
    { // LeftEye24, 46
    B01111110,
    B11111111,
    B11111111,
    B11100111,
    B11100111,
    B11111111,
    B11111110,
    B01111100
    byte RightEye24[]=
    { // RightEye24, 47
    B01111100,
    B11111110,
    B11111111,
    B11100111,
    B11100111,
    B11111111,
    B11111111,
    B01111110
    byte LeftEye25[]=
    { // LeftEye25, 48
    B01111110,
    B11111111,
    B11111111,
    B11100111,
    B11100111,
    B11111110,
    B11111100,
    B01111000
    byte RightEye25[]=
    { // RightEye25, 49
    B01111000,
    B11111100,
    B11111110,
    B11100111,
    B11100111,
    B11111111,
    B11111111,
    B01111110
    byte LeftEye26[]=
    { // LeftEye26, 50
    B01111110,
    B11111111,
    B11111111,
    B11100111,
    B11100110,
    B11111100,
    B11111000,
    B01110000
    byte RightEye26[]=
    { // RightEye26, 51
    B01110000,
    B11111000,
    B11111100,
    B11100110,
    B11100111,
    B11111111,
    B11111111,
    B01111110
    byte LeftEye27[]=
    { // LeftEye27, 52
    B01111110,
    B10011001,
    B10011001,
    B10000001,
    B10000001,
    B10000001,
    B10000001,
    B01111110
    byte RightEye27[]=
    { // RightEye27, 53
    B01111110,
    B10011001,
    B10011001,
    B10000001,
    B10000001,
    B10000001,
    B10000001,
    B01111110
    byte LeftEye28[]=
    { // LeftEye28, 54
    B01111110,
    B10011001,
    B10000001,
    B10000001,
    B10000001,
    B10000001,
    B10000001,
    B01111110
    byte RightEye28[]=
    { // RightEye28, 55
    B01111110,
    B10011001,
    B10000001,
    B10000001,
    B10000001,
    B10000001,
    B10000001,
    B01111110
    void setup()
    // initialize the 8X8 LED matricies
    lc.shutdown(0,false); // Wake up displays
    lc.shutdown(1,false);
    lc.setIntensity(0,5); // Set intensity levels
    lc.setIntensity(1,5);
    lc.clearDisplay(0); // Clear Displays
    lc.clearDisplay(1);
    //Initializes the WTV020 module.
    wtv020sd16p.reset();
    randomSeed(analogRead(0));
    delay(1000);
    void sinvader1a()
    for (int i = 0; i < 8; i++)
    lc.setRow(0,i,invader1a[i]);
    void sinvader1b()
    lc.setRow(0,i,invader1b[i]);
    void LeftEye1a()
    lc.setRow(0,i,LeftEye1[i]);
    void LeftEye2a()
    lc.setRow(0,i,LeftEye2[i]);
    void LeftEye3a()
    lc.setRow(0,i,LeftEye3[i]);
    void LeftEye4a()
    lc.setRow(0,i,LeftEye4[i]);
    void LeftEye5a()
    lc.setRow(0,i,LeftEye5[i]);
    void LeftEye6a()
    lc.setRow(0,i,LeftEye6[i]);
    void LeftEye7a()
    lc.setRow(0,i,LeftEye7[i]);
    void LeftEye8a()
    lc.setRow(0,i,LeftEye8[i]);
    void LeftEye9a()
    lc.setRow(0,i,LeftEye9[i]);
    void LeftEye10a()
    lc.setRow(0,i,LeftEye10[i]);
    void LeftEye11a()
    lc.setRow(0,i,LeftEye11[i]);
    void LeftEye12a()
    lc.setRow(0,i,LeftEye12[i]);
    void LeftEye13a()
    lc.setRow(0,i,LeftEye13[i]);
    void LeftEye14a()
    lc.setRow(0,i,LeftEye14[i]);
    void LeftEye15a()
    lc.setRow(0,i,LeftEye15[i]);
    void LeftEye16a()
    lc.setRow(0,i,LeftEye16[i]);
    void LeftEye17a()
    lc.setRow(0,i,LeftEye17[i]);
    void LeftEye18a()
    lc.setRow(0,i,LeftEye18[i]);
    void LeftEye19a()
    lc.setRow(0,i,LeftEye19[i]);
    void LeftEye20a()
    lc.setRow(0,i,LeftEye20[i]);
    void LeftEye21a()
    lc.setRow(0,i,LeftEye21[i]);
    void LeftEye22a()
    lc.setRow(0,i,LeftEye22[i]);
    void LeftEye23a()
    lc.setRow(0,i,LeftEye23[i]);
    void LeftEye24a()
    lc.setRow(0,i,LeftEye24[i]);
    void LeftEye25a()
    lc.setRow(0,i,LeftEye25[i]);
    void LeftEye26a()
    lc.setRow(0,i,LeftEye26[i]);
    void LeftEye27a()
    lc.setRow(0,i,LeftEye27[i]);
    void LeftEye28a()
    lc.setRow(0,i,LeftEye28[i]);
    ////////////////// RIGHT SIDES ////////////////////////
    void sinvader2a()
    lc.setRow(1,i,invader2a[i]);
    void sinvader2b()
    lc.setRow(1,i,invader2b[i]);
    void RightEye1b()
    lc.setRow(1,i,RightEye1[i]);
    void Blink()
    /////FRAME 1 ////
    delay(80);
    /////FRAME 2 ////
    lc.setRow(1,i,RightEye2[i]);
    delay(80);
    /////FRAME 3 ////
    lc.setRow(1,i,RightEye3[i]);
    delay(80);
    /////FRAME 4 ////
    lc.setRow(1,i,RightEye4[i]);
    delay(150);
    /////FRAME 5 ////
    delay(80);
    /////FRAME 6 ////
    delay(100);
    /////FRAME 7 ////
    delay(80);
    void FastBlink()
    /////FRAME 1 ////
    delay(30);
    /////FRAME 2 ////
    delay(30);
    /////FRAME 3 ////
    delay(30);
    /////FRAME 4 ////
    delay(60);
    /////FRAME 5 ////
    delay(30);
    /////FRAME 6 ////
    delay(30);
    /////FRAME 1 ////
    delay(30);
    void Stare()
    /////FRAME 1 ////
    delay(250);
    void LookLeft()
    /////FRAME 1 ////
    lc.setRow(1,i,RightEye12[i]);
    delay(500);
    /////FRAME 1 ////
    delay(100);
    void LookRight()
    /////FRAME 1 ////
    lc.setRow(1,i,RightEye10[i]);
    delay(500);
    /////FRAME 1 ////
    delay(100);
    void LeftCWSpin()
    ///// 12, 11,10, 14,12, 1
    /////FRAME 1 ////
    delay(50);
    /////FRAME 2 ////
    lc.setRow(1,i,RightEye11[i]);
    delay(50);
    /////FRAME 3 ////
    delay(50);
    /////FRAME 4 ////
    lc.setRow(1,i,RightEye14[i]);
    delay(50);
    /////FRAME 5 ////
    delay(50);
    /////FRAME 6 ////
    delay(50);
    void RightCCWSpin()
    ///// 10,11,12,14
    /////FRAME 1 ////
    delay(50);
    /////FRAME 2 ////
    delay(50);
    /////FRAME 3 ////
    delay(50);
    /////FRAME 4 ////
    delay(50);
    void Angry()
    ///// 24,25,26
    /////FRAME 1 ////
    lc.setRow(1,i,RightEye24[i]);
    delay(50);
    /////FRAME 2 ////
    lc.setRow(1,i,RightEye25[i]);
    delay(50);
    /////FRAME 3 ////
    lc.setRow(1,i,RightEye26[i]);
    delay(250);
    void BallFlash()
    delay(80);
    lc.setRow(1,i,RightEye13[i]);
    delay(80);
    void SquareFlash()
    lc.setRow(1,i,RightEye23[i]);
    delay(60);
    lc.setRow(1,i,RightEye22[i]);
    delay(60);
    void Hypno()
    lc.setRow(1,i,RightEye18[i]);
    delay(75);
    lc.setRow(1,i,RightEye19[i]);
    delay(75);
    lc.setRow(1,i,RightEye20[i]);
    delay(75);
    void loop()
    //Plays synchronously an audio file. Busy pin is used for this method.
    FastBlink();
    delay(100);
    int x = random(15,25); //add randomness to the sound selection min # is inclusive, max # is exclusive
    delay (20);
    wtv020sd16p.playVoice(x);
    delay(50);
    x= random(1,10); //add some randomness to the routine
    for ( int i=0; i <x ; i++)
    { Stare();
    delay (1500);
    FastBlink();
    delay(200);
    Stare();
    delay(500);
    Blink();
    delay(1000);
    Stare();
    delay(1500);
    FastBlink();
    delay(200);
    FastBlink();
    delay(300);
    Blink();
    delay(1000);
    x= random(1,9); //add some randomness to the routine
    LookLeft();
    delay(1000);
    LookRight();
    delay(1000);
    { LeftCWSpin();
    delay(50);
    x= random(1,6); //add some randomness to the routine
    { Stare();
    delay (1000);
    FastBlink();
    delay(200);
    Stare();
    delay(500);
    { RightCCWSpin();
    delay(50);
    Stare();
    delay(2000);
    //Stops current audio file playing.
    wtv020sd16p.stopVoice();
    Angry();
    x= random(0,15);
    delay(5000);
    FastBlink();
    FastBlink();
    // check to see if a audio clip is still playing, if not, then start a new one
    int y = digitalRead(5); //read WTV020 busypin
    if (y==LOW)
    { x= random(15,25);
    wtv020sd16p.playVoice(x);}
    Angry();
    delay(5000);
    if (y=LOW)
    { x= random(15,25);
    Stare();
    delay(1000);
    if (y==LOW)
    { x= random(15,25);
    /////////////crazy Eyes
    { BallFlash();
    delay(20);
    if (y==LOW)
    { x= random(15,25);
    x= random(1,12); //add some randomness to the routine
    { Hypno();
    delay(20);
    if (y==LOW)
    { x= random(15,25);
    { SquareFlash();
    delay(15);
    Stare();
    delay(1000);
  • pcmofo
    pcmofo over 2 years ago in reply to dougw
    Thanks! these are very helpful links
  • pcmofo
    pcmofo over 2 years ago in reply to scottiebabe
    Cool, I'll definitely check out framebuffer, thanks!
  • pcmofo
    pcmofo over 2 years ago in reply to robogary
    Awesome! thanks for sharing. It looks like we took a very similar approach to doing this. I built a "Lite bright" style iOS app that dumps the output very similar to your spreadsheet.
