Arduino Forum Circuit Review
  • Replies 42 replies
  • Subscribers 416 subscribers
  • Views 5354 views
Circuit Review
s1buell
s1buell over 8 years ago
  I`m currently making some proto circuits and I would love some feed back/Ideas etc.
All these circuits will connect to Arduino or Arduino compatible devices.
Anyone have time to help out with some reviews?
First circuit is a 4-20ma board
    genebren over 8 years ago in reply to s1buell +4
    You might need to modify your 4-20ma loop front end somewhat. First, the circuit as shown does not have a return path for the current loops. Also, the current loop may not necessarily be directly referenced…
    Tom, Again, I am not sure that you can count on the second leg of the 4-20ma loop to be at ground potential. You might end up shorting out a driver or introducing ground noise into the circuit. Here is…
    Tom, Here is an even better link. This shows how to differential sense the loop current. https://www.sensorsmag.com/components/implementing-a-4-ma-to-20-ma-sensor-interface Good luck! Gene
  • s1buell
    s1buell over 8 years ago in reply to s1buell
    Bump.... Anyone?
    dougw over 8 years ago in reply to s1buell
    Shouldn't the protection diode be on the other side of the resistors?
