Arduino Forum UNO + CNC Shield requires hand held controller / pendant
  • Subscribers 415 subscribers
  • Views 2651 views
ukcd
ukcd over 7 years ago
Hello i'm new to the site, new to Arduino & really new to online forums, so go easy on me please......
I have just ordered an Arduino UNO, cnc shield & a 3.5" touch screen lcd module to try to control a cnc router machine i am building.
NOW, i have multiple questions....
1. Is there a way to use some form of handheld remote / pendant type thingy to control the x, y & z axis on my cnc router?
2. Does the UNO & cnc shield use the same PSU? (e.g. to power uno & drive nema 23 steppers)
3. If the answer to Q2 is NO, then how do I work out what PSU's I will need?
4. Is it just a case of uploading the GRBL firmware to run this thing?
Thanks in advance & remember I'm a total new comer to this so simple would be good.
    genebren over 7 years ago +2
    Hi Mark, Welcome to the element14 community! There are a lot of friendly and helpful folks here, so don't worry too much about being new and not really knowing everything about what you are doing. We are…
  • ukcd
    ukcd over 7 years ago in reply to genebren +2
    Hey thanks Gene, thats a great help. Yes that is the same cnc shield as i have ordered. 1616.contentimage_3.png
    Hi Mark,
    Welcome to the element14 community!  There are a lot of friendly and helpful folks here, so don't worry too much about being new and not really knowing everything about what you are doing.  We are here to help.
    I have to  say I am not an expert in CNC or using arduino, but I have followed some of this as it intersects with a lot of my interests.
    Here is some links to using SNES type controllers with an aurdino (just to give you some ideas of what might work):
    https://hackaday.io/project/7498-snes-controller-arduino-adapter
    https://nickjmeyer.github.io/arduinos/2015/11/16/Reading-SNES.html
    It appears the the cnc shield does have a separate power source connection for the the motor/drivers (assuming that I found the same shield you are looking at).
    Here is an interesting link on this board:
    Arduino CNC Shield Instructions
    I hope this helps you get started.  I am sure that there are others members that might have gone down this same road before and hopefully one of them will jump in and help.
    Good luck!
    Gene
  • ukcd
