Arduino Forum Tips on what sensor to use to measure lux levels?
  • Subscribers 414 subscribers
  • Views 1892 views
johnlarry
johnlarry over 7 years ago
Hello-
I have beginner level knowledge when it comes to Arduino, but I'm looking for a basic sensor that is able to measure lux levels when placed out in the sun. Eventually that data will be used to rotate a servo motor x amount of degrees based on variable lighting conditions.
Based on the small amount of research I've done so far, I've come across Sarkari Result Pnr Status
  • BH1750 Showbox
  • TSL2561
and I'm curious if anyone has experience with these sensors or is willing to add any recommendations.
Thanks in advance!
  • fmilburn
    fmilburn over 7 years ago +5
    Hello John, I have used the TSL2561 and the Rohm RPR-0521RS with Arduino / Energia. I have not used the BH1750. My RoadTest of the RPR-0521 is here: Rohm Sensorshield Roadtest and I used the Rohm library…
  • Gough Lui
    Gough Lui over 7 years ago +5
    Be aware that some attenuation may be necessary. In my experience, some of the lux sensors are designed for integration into areas like smartphone mobile displays for auto-brightness feedback and will…
  • beacon_dave
    beacon_dave over 7 years ago +4
    There is a small Arduino based photometer project documented in this book: https://www.elektor.com/arduino-uno-45-projects-for-beginners-and-experts which may be of interest. It's just using an LDR and…
  • fmilburn
    Hello John,
    My RoadTest of the RPR-0521 is here:  Rohm Sensorshield Roadtest  and I used the Rohm library with an Arduino.  Several other Element14 members  participated in this Roadtest also.  My thoughts on the TSL2561 are here:  TSL2561.  I used the Adafruit Arduino library with a Texas Instruments LaunchPad and Energia but modified it so that it would auto-range.
    My preference is for the Rohm sensor as it does not saturate like the TSL2561 does if pointed directly at the sun.  I found it reasonably accurate for the limited testing I did by comparing readings to those of my DSLR camera.
    Frank
    • Vote Up +5 Vote Down
  • Gough Lui
    Be aware that some attenuation may be necessary. In my experience, some of the lux sensors are designed for integration into areas like smartphone mobile displays for auto-brightness feedback and will not be able to handle full direct sun without saturating readings. A neutral density glass filter may be placed over the top of the sensor to extend its range.
    - Gough
  • beacon_dave
    which may be of interest. It's just using an LDR and some basic math to output an estimated Lux value.
  • BigG
    BigG over 7 years ago
    As mentioned by others, saturation levels are a key consideration.
    Another one for the list is the TSL2591 which can handle a higher lux level than the TSL2561 can.
    Adafruit have a breakout board should you want to test: https://learn.adafruit.com/adafruit-tsl2591
    With both the TSL2561 and the TSL2591 there are a range of settings you can adjust to improve measurement quality.
