Arduino Forum Arduno Code to C/C++ for LED Cube
  • Subscribers 415 subscribers
  • Views 1465 views
  • led_cube
  • programming in c
  • led cube
  • c++ coding
  • 4x4_led_cube
dzuz
dzuz over 7 years ago
Does anyone know how to convert arduino code to c/c++?
I have made a 4x4x4 LED cube, but I need to have the code in c/c++, not just arduino code.
If anyone knows of a converter or can link a site to easily learn c/c++ on an arduino, that would be greatly appreciated. Thanks!
-Dan
  • fmilburn
    fmilburn over 7 years ago +3
    Hi Daniel, Arduino code is C++ in an IDE with pin mapping and standard access to timers and other hardware features regardless of the microcontroller. There are also numerous libraries providing access…
  • fmilburn
    Hi Daniel,
    Arduino code is C++ in an IDE with pin mapping and standard access to timers and other hardware features regardless of the microcontroller.  There are also numerous libraries providing access to sensors, LEDs, motors and such.
    So there is no conversion to C++ since it is already C++.  But it will be necessary to do all of the underlying register setting and library writing that an Arduino already provides.  In other words you will need to learn to implement basic C++ on a microcontroller - without this you will be lost.  It would be difficult to comment further without knowing the microcontroller you are using but my recommendation is to select one with good tutorials for getting started. You will need to learn how to use timers and set and change a gpio pin as a start.
    Frank
  • dzuz
    I was instructed to change the code below into C or C++. I have to do it with out using digitalwrite. I tried something, to turn all LEDs (turnEverythingOn();) on with the code all the way at the bottom (bolded). Is anyone able to confirm that my code would work?
    //initializing and declaring led rows
      int column[18]={13,12,11,10,9,8,7,6,5,4,3,2,1,0,A5,A4};
    //initializing and declaring led layers
      int layer[4]={A3,A2,A1,A0};
      int time = 250;
    void setup()
      //setting rows to ouput
      for(int i = 0; i<16; i++)
        pinMode(column[i], OUTPUT);
      //setting layers to output
      for(int i = 0; i<4; i++)
        pinMode(layer[i], OUTPUT);
      //seeding random for random pattern
      randomSeed(analogRead(10));
    //xxxxxxxxxxxxxxxxxxxxFUNCTION LOOPxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    //xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    void loop()
      turnEverythingOff();//turn all off
      flickerOn();
      turnEverythingOn();//turn all on
    void turnEverythingOff()
         digitalWrite(column[i], 1);
         digitalWrite(layer[i], 0);
    ////////////////////////////////////////////////////////////turn all on
    void turnEverythingOn()
        digitalWrite(column[i], 0);
      //turning on layers
        digitalWrite(layer[i], 1);
    ///////////////////////////////////////////////////////turn columns off
    void turnColumnsOff()
    /////////////////////////////////////////////////////////////flicker on
    void flickerOn()
      int i = 150;
      while(i != 0)
        turnEverythingOn();
        delay(i);
        delay(i);
        i-= 5;
    void loop()
    turnEverythingOn();
    DDRD = 0xFF; //setting outputs
    DDRC = 0x3F;
    DDRB = 0xC3;
    PORTD = 0xFF; //PD0-PD7 8pins
    PORTB.0 = 0xFF; //PB0 & PB1 2pins
    PORTB.1 = 0xFF;
    PORTC.0 = 0xFF; //PC0-PC5 6pins
    PORTC.1 = 0xFF;
    PORTC.2 = 0xFF;
    PORTC.3 = 0xFF;
    PORTC.4 = 0xFF;
    PORTC.5 = 0xFF;
  • dzuz
    I try to compile the code and I keep getting this error. Does anyone know how I could resolve this issue?
    Thanks!
