Arduino Forum Digital volume control
  • Replies 16 replies
  • Subscribers 415 subscribers
  • Views 3496 views
  • audio
  • app
  • Speakers
ctucht16
ctucht16 over 7 years ago
Hello every one I have a project I would like to try at work. We have an old radio at one bench and speakers running to every other bench. The volume is a pain to change. I thought what if I built an app that every one can change the volume individualy on our own workstations. I tried doing some reading on digital pots but I'm still lost in the sauce and am in serrious need of help.
So I need something to controll the speakers and design the app to controll the speakers from multiple computers on a network.
    shabaz over 7 years ago +2
    Wow, I'm not sure I could work with a speaker nearby that I couldn't easily turn down/switch off at times. If you're just interested in productivity and want to have a quick solution, consider something…
    Jan Cumps over 7 years ago in reply to Jan Cumps +1
    One of the possibilities is digital programmable logarithmic potentiometers, e.g.: https://www.analog.com/media/en/news-marketing-collateral/product-selection-guide/Choosing_the_Correct_Digipot.pdf If…
    Jan Cumps over 7 years ago in reply to shabaz +1
    shabaz wrote: .... but I don't know what power level the amp operates at, ‘.. 30 Watt per channel. It’s a serious kit.
    DAB over 7 years ago
    I would use a PSOC 4000 series MCU with user programmable analog devices.
    You could use the capacitive sense switches to control the volume on the analog amplifiers to drive the speakers.
    At most you might need a LM386 audio amp to boost the speaker drive for volume.
    What is going to the benches? Direct wires to the speakers, from the radio speaker output?
  • ctucht16
    ctucht16 over 7 years ago in reply to Jan Cumps
    We have standard speaker cables from a Niles SI-1230 12-Channel Power Amplifier connected to the speaker
  • ctucht16
    ctucht16 over 7 years ago in reply to DAB
    We have a Niles SI-1230 12 channel power amp will that work
    Jan Cumps over 7 years ago in reply to ctucht16
    With this back panel?
    If you take i2c programmable ones, quad type, you can replace the 12 volume controls by 3 ICs.
    (check inside the app what type these volume controls are)
    If you're just interested in productivity and want to have a quick solution, consider something like this 12-way rotary switch12-way rotary switch
    and lots of 10 ohm resistors (probably 1/2W ones should be fine, but I don't know what power level the amp operates at, so you may wish to go for (say) 1W resistors for some of them).
    Not the same as a remote-controlled app, but maybe quicker to assemble, connected directly to the speaker connections on your desk.
    shabaz over 7 years ago in reply to Jan Cumps
    I see.. in that case, if it's cranked to the max, then at least 7W per resistor is needed for the first couple, reducing to about 5W or below for the remainder. These MCKNP 5W resistors are cheap, some could be paralleled for >7W capability (i.e. just buy all of the same value to get cheaper bulk cost).
    But it's not the same as digital control so maybe a redundant suggestion.
  • ctucht16
    Yes that is the back
