Arduino Forum Digital volume control
  • Replies 16 replies
  • Subscribers 415 subscribers
  • Views 3509 views
  • audio
  • app
  • Speakers
ctucht16
ctucht16 over 7 years ago
Hello every one I have a project I would like to try at work. We have an old radio at one bench and speakers running to every other bench. The volume is a pain to change. I thought what if I built an app that every one can change the volume individualy on our own workstations. I tried doing some reading on digital pots but I'm still lost in the sauce and am in serrious need of help.
So I need something to controll the speakers and design the app to controll the speakers from multiple computers on a network.
    shabaz over 7 years ago +2
    Wow, I'm not sure I could work with a speaker nearby that I couldn't easily turn down/switch off at times. If you're just interested in productivity and want to have a quick solution, consider something…
    Jan Cumps over 7 years ago in reply to Jan Cumps +1
    One of the possibilities is digital programmable logarithmic potentiometers, e.g.: https://www.analog.com/media/en/news-marketing-collateral/product-selection-guide/Choosing_the_Correct_Digipot.pdf If…
    Jan Cumps over 7 years ago in reply to shabaz +1
    shabaz wrote: .... but I don't know what power level the amp operates at, ‘.. 30 Watt per channel. It’s a serious kit.
  • ctucht16
    ctucht16 over 7 years ago in reply to shabaz
    Thank you but its not a fix I need quick its more of a project I want to try.
  • ctucht16
    ctucht16 over 7 years ago in reply to Jan Cumps
    What do you recommend? I know nothing about digipots
    Jan Cumps over 7 years ago in reply to ctucht16
    If you want to control the volume from computers, you will need to replace the volume controls on the back of the amplifier by computer controllable potentiometers.
    That's why I suggested digipots. They can be controlled by digital signals
    Another option are motor controlled potentiometers. They are more expensive.
    Do you know how to control something like that?
  • ctucht16
    https://ncd.io/ would there be something that could work on here?
    3 of these: https://store.ncd.io/product/analog-devices-ad5254-digital-potentiometer-4-channel-256-position-i2c-mini-module/
    Each can replace 4 potentiometers. The potentiometers are linear, so it will be a little bit uncomfortable for sound volume changes.
    Don't take the single or dual potentiometer kits, because there are only 4 addresses you can assign to these modules and you need to cover 12v potentiometers with these 4 addresses.
    They are programmable over i2c.
    If may be possible to simulate a logarithmic control by doing the calculations yourself in software.
    You will also need a device that can listen to all your computers and generate an i2c signal, and 5V dc, 15 mA power supply - and wire.
    The good thing with i2c is that you can put all 3 kits on the same i2c bus.
  • billpenner
    billpenner over 7 years ago in reply to ctucht16
    Question. Do you want the volume controls at the amplifier or at each speaker.
    If at each speaker, google "speaker volume controls" there many to choose from.
    Impedance matching is probably necessary unless you are using low wattage speakers
    in which case, a simple low wattage wire wound potentiometer might work.
    These methods would require the Max volume to be set at the amplifier with the individual controls set at 0 Ohms
    each station could then reduce the volume as needed. the value of pots would need to be selected so as to allow desired volume reduction.
