Arduino Forum which gps shield and module for Arduino Uno
  • Replies 29 replies
  • Answers 2 answers
  • Subscribers 420 subscribers
  • Views 3631 views
  • robot
  • arduino_uno
  • gps_antenna
  • gps_shield
  • gps_module
EmreKon1
EmreKon1 over 13 years ago
i wanna make gps quided car with Arduino Uno R3. which gps shield, module and antenna may i buy?
  • Lupo
    Lupo over 13 years ago in reply to EmreKon1 +1
    There is also this one, very interesting: http://www.open-electronics.org/gsm-gps-shield-for-arduino/
  • fustini
    0 fustini over 13 years ago
    I've heard good things about Adafruit's Ultimate GPS breakout board: http://adafruit.com/products/746
    They have nice tutorial for it, too: http://learn.adafruit.com/adafruit-ultimate-gps
  • EmreKon1
    0 EmreKon1 over 13 years ago in reply to fustini
    tjank you for answering.
    nice choise but 39.95$+7.16$ shipping. Good money. im searching something cheap. because i will buy it to learn gps programming than i will buy quality one.
    http://dx.com/et-318-gps-engine-board-module-with-sirf-star-iii-chipset-80049?item=5
    10.49$   so what about that?? can i find right gps shield for that?
  • EmreKon1
    is that shield suitable for Arduino??     26.40$   +   free shipping
    http://dx.com/cn-06-gps-receiver-super-u-blox-gps-module-w-active-ceramic-antenna-mwc-149340?item=1
  • fustini
    0 fustini over 13 years ago in reply to EmreKon1
    I don't think either would be compatible with a shield per se, but that last one says it does have TTL serial so I'm thinking you could probably communicate with the Arduino that way.  Hopefully some others in this group can chime in with GPS recommendations from projects they've worked on.
  • simon.monk
    0 simon.monk over 13 years ago in reply to fustini
    I have used the Sparkfun Venus module with an Arduino.
    Write-up and code here: http://www.doctormonk.com/2012/05/sparkfun-venus-gps-and-arduino.html
    http://3.bp.blogspot.com/-8gC6yuylER8/T8eBC7JLzVI/AAAAAAAAA0A/Ls1FBccomJg/s640/venus_sm.jpg
  • EmreKon1
    0 EmreKon1 over 13 years ago in reply to simon.monk
    thank you but venus gps module is (49.95 $ + shipping) nice price imageimage
    what do you think about http://dx.com/cn-06-gps-receiver-super-u-blox-gps-module-w-active-ceramic-antenna-mwc-149340?item=1
    is it compatible with arduino?
  • simon.monk
    0 simon.monk over 13 years ago in reply to EmreKon1
    It says its TTL UART - same as Venus - so, yes should be fine and my example code should work. It doesn't specify baud rate, so you may have to experiment.
    At that price, its worth a go anyway!
  • EmreKon1
    http://www.u-blox.com/images/downloads/Product_Docs/NEO-6_DataSheet_%28GPS.G6-HW-09005%29.pdf
    datasheet of "U-blox NEO-6M GPS module".          at last i can find the datasheet image
    after looking at datasheet, can you say it is compatible with your "example code" and Arduino Uno R3 ??
  • simon.monk
    What supply voltage does it use?
    What is the voltage level of the serial connection?
    Ideally, you want both to be 5V.
  • EmreKon1
    Power supply voltage (VCC)                  Min:2.7V      Typ:3.0V      Max:3.6V
    Supply voltage USB (VDDUSB)             Min:3.0V      Typ:3.3V      Max:3.6V
    can i conntect arduino's  3.7 V pin ?
