Arduino Forum which gps shield and module for Arduino Uno
  • Replies 29 replies
  • Answers 2 answers
  • Subscribers 420 subscribers
  • Views 3692 views
  • robot
  • arduino_uno
  • gps_antenna
  • gps_shield
  • gps_module
EmreKon1
EmreKon1 over 14 years ago
i wanna make gps quided car with Arduino Uno R3. which gps shield, module and antenna may i buy?
  • Lupo
    Lupo over 14 years ago in reply to EmreKon1 +1
    There is also this one, very interesting: http://www.open-electronics.org/gsm-gps-shield-for-arduino/
  • simon.monk
    0 simon.monk over 14 years ago in reply to EmreKon1
    Ah, okay, well the Uno can supply 50mA at 3.3V, how many mA does the module need?
    If you connect the Tx of the module to the Rx of the Uno and DO NOTwire the Tx of the Uno to the Rx of the module, then the 5V Arduino will be able to read the 3.3v serial signal from the gps module. It will mean you have to take the default settings of the GPS module as far as baud rate etc goes. Its probably 9600 8N1 so you should be okay.
    If you do decide you need to send data from the Uno to the GPS, you will have to use a level converter. Buts lets cross that bridge if we come to it image
  • EmreKon1
    0 EmreKon1 over 14 years ago in reply to simon.monk
    Condition :      VCC=3.0V
    Icc Acquisition : 47mA
    Icc Tracking (Max Performance mode) : 40mA
    Icc Tracking (Eco mode) : 37mA
    Icc Tracking (Power Save mode / 1 Hz) : 11mA
    UARTBaud rate : 9600 (USB powered)
    http://www.u-blox.com/images/downloads/Product_Docs/NEO-6_DataSheet_%28GPS.G6-HW-09005%29.pdf
    datasheet for neo-6 gps module
  • simon.monk
    Looks like it should be just okay image
    Anything I haven't thought of anyone?
  • EmreKon1
    Thank you too much:) i will buy and try than i will write here :)
  • simon.monk
    No problem. Please do post back - if they are any good, I'll probably get one too. image
    Did you see the brushless quadcopter motors for $13 on that web page? Amazingly cheap.
  • EmreKon1
    dealextreme is my nu 1 :) so cheap and free shipping :) i strongly reccomend.
    I will also ask you about quadrocopter parts but not that time becouse im not at that level:)
  • EmreKon1
    http://www.AeroQuadStore.com/Logic_Level_Converter_p/bob-08745.htm
    Can i use  "logic level converter" to  convert 5.0V of arduino to gps's 3.6V
    Or
    Is arduino's 3,7V pin enough?
  • simon.monk
    You can power it from the Arduino 3.3V power connection.
    Remember do not connect the Arduino Tx to the GPS Rx - that will quite likely kill it.
    Only connect the Arduino Rx to the GPS Tx,
    GND to GND
    and Arduiono 3.3V to GPS VCC.
  • EmreKon1
    Thank you again:) i bought it. It will be my hand 15 daysy later than i will post my experiences with you:)
    please post how you connect the module to the Arduino it. I can not find the manual in Russian, and even in English. Is there a sketch to work with this module?
    I bought it in ebay here in this form.
    Thank you friends, I'm sorry for my English, I use google translate
