Arduino
Arduino
Documents is arduinouno and Atmega328 controller performance same?
  • Date Created: 1 May 2014 8:49 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:50 AM
  • Views 2167 views
  • Comments 12 comments
Hello all,
  i want to know arduino and Atmega are different controllers or same.
  • dil1
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    no problem, just edit the previous one to let us know you have done that... it would help alot in the future
    Thanks
    SORRY PETER,
    BUT I DIDN'T GET RPLY THERE WITHIN 2 DAYS SO I POST THE SAME QUESTION HERE.AND THE FIRST ONE IS NOT RELATED TO THIS QUESTION.AND THANX FOR ALL YOUR RESPONSE.
    Then If I may on behalf of the active members answering and helping allot on the forums, please restrict the question to one thread as is is difficult enough tracking member questions across the forums without having to answer the same person three time for the same question and if we ignore the other two it looks bad on the community as it seems to others were not helping
    If you really must do this then simply link from that forum to the primary question and state it is a duplicate from another thread... ie help us to be more eficient
    thanks
    Peter
    Dear mcb and john,
        other 2 are also my  post.
    mcb1 over 12 years ago in reply to Problemchild
    Similar to tracing spam posts.
    Once you find the first, have a look at the persons profile and see his authored posts.
    Not sure if its the best, but is the easiest I have found.
  • Problemchild
    Problemchild over 12 years ago in reply to mcb1
    Good find Mark, what search terms did you use to find that , for folk's future reference?
    mcb1 over 12 years ago in reply to e14 Contributor
    And the other posting asking similar questions
    http://www.element14.com/community/thread/33437/l/is-arduino-and-atmega328-performance-same
    is arduino reliable for industrial environment for industrial application?
    thanx to everyone.
    but i want to know about uno only.i heard Atmega328 used in industrial application.so why not arduino??
  • Problemchild
    As Mark said the great majority of Arduinos in use use the AtMega 328 chip  there's very little extra hardware on an Arduino and if you put the boot loader on the chip the performance will be the same.
    However over the years there has been a proliferation of variations of Arduino designs most been similar to above but others like the Arduino Mega or Leonardo for example use the AtMega 2560 and At32u4 CPUs respectively with differing specs to the '328 CPU.
    Further more the latest Arduinos are based on totally different Architectures such as the cortex M3 based Atmel SAM3X8E on the Arduino Due  http://arduino.cc/en/Main/arduinoBoardDue
    Basically yes they are the same, but remember the fringe cases where some one has done something different
    To clarify, Ardiono is an echo system based on the atmel ATMEGAxxxx series's of microcontrollers
    It would be inaccurate to say that an arduino is the same as an atmega328, it very much depends on which arduino board you select
    An arduino uno is based on the 328 but an arduino mega is based on the 2560 CPU and they have different capabilities
    All the differences are clearly detailed on the arduino web site, just navigate there and you will find everything you need
