AUBoard 15P OOB - QC test not passed
  • Subscribers 259 subscribers
  • Views 518 views
iulyanov
iulyanov 8 months ago
I am working with the AUBoard-15P carrier together with my own custom FMC card. Earlier, my FMC card had a hardware issue that caused voltage drops on the AUBoard 3.3 V rail. I have now removed the FMC card and I am trying to restore the board to a known-good state by reflashing the official Out-of-Box image to the on-board QSPI flash.
I used the OOB package from: http://avnet.me/auboard-15p-dk-oob and programmed the provided au15p_firmware.mcs into QSPI using Vivado Hardware Manager.
After reflashing, the board no longer starts the web-server demo.
Instead, the UART log shows:
AU15P Board SPI Flash Bootloader v1.0 Build on Oct 15 2024
INFO: QC test not passed, launch QC test program now.
Boot application AU15P_TEST.elf
XEMacLite detect_phy: PHY detected at address 1.
auto-negotiated link speed: 100
The bootloader launches AU15P_TEST.elf instead of the expected OOB application / web server.
So, my question is
  1. Is the QC/test application source code available, or at least a description of what it checks? I would like to identify whether the earlier FMC-related fault may have damaged some part of the carrier board. I have strong concerns about it.
  2. Maybe I am using an OOB image that is not appropriate for my board version, and the board itself is OK? My board is AUB-15P-DK-PCB-1
Any guidance would be appreciated. Thank you.
  • iksevas
    iksevas 8 months ago in reply to iksevas +2 suggested
    Here is an OOB MCS file that you should be able to program. I will have the team update the MCS file online. Let me know if this works for you. community.element14.com/.../au15p_5F00_oob.zip
  • iksevas
    0 iksevas 8 months ago
    I believe there is a software check that requires the QC Test to pass before programming the Out of box. You won’t be able to pass that test without test equipment.
    II’ll get back to you after done review to see if you gave option to program OOB mcs without factory test.
  • iksevas
    0 iksevas 8 months ago in reply to iksevas
    Here is an OOB MCS file that you should be able to program. I will have the team update the MCS file online. Let me know if this works for you.au15p_oob.zip
  • iulyanov
    0 iulyanov 8 months ago in reply to iksevas
    Hi iksevas,
    Thank you. With this file everything worked as expected out-of-the-box. The server started successfully. So, fortunately, my FMC did not damage the carrier.
    It would indeed be good to update the online link to the working OOB version. Thanks again for your attention, the issue is now resolved.
