AUBoard 15P Vivado version & PCIe XDMA reference
  • Subscribers 260 subscribers
  • Views 520 views
rogroote
rogroote 6 months ago
Hi all,
I am looking for a reference PCIe XDMA design (Vivado project + host driver).
Does anyone have a link to a solid / proven PCIe project targeting the AUBoard 15P?
In addition:
Which Vivado version(s) would you recommend for this board and XDMA?
Any known pitfalls or good practices for this specific platform are also welcome.
Thanks in advance.
Kind regards
  • iksevas
    iksevas 6 months ago +2 verified
    I think you can retarget the XDMA reference design to any of the tools for the most part. two gotchas: 1) generating the PCIe IP requires you to generate GT lanes to target the AUBoard. This differs…
  • iksevas
    0 iksevas 6 months ago
    two gotchas:
    1) generating the PCIe IP requires you to generate GT lanes to target the AUBoard. This differs from the default settings which more than likely were set to a different board. There is a check box on the last page of the IP settings which allows you to override the default so your XDC will actually take effect.
    2) Rev 1 of the AUBoard has wrong capacitance value on the PCIe interface to support Gen 4 properly. This is elder to be resolved with a Rev 2 boards available next month.
  • iksevas
    0 iksevas 6 months ago in reply to iksevas
    FYI - there is an article that Adam Taylor wrote called Perfecting PCIe on AUBoard I believe which should get you started down the correct path.
  • rogroote
    0 rogroote 6 months ago in reply to iksevas
    Thanks. Our application requires PCIe Gen4 x4 and DDR4 at maximum speed, so upgrading to revision 2 of the board is necessary.
  • iksevas
    0 iksevas 6 months ago in reply to rogroote
    There 8 are capacitors on the board that are changing values to support Gen 4.
