AUBoard 15P In Evaluation board AUBoard-15P Development Kit that we just got, we can not get the PCIe to work. Any input on what is that we are missing
  • +1 person also asked this people also asked this
  • Subscribers 261 subscribers
  • Views 244 views
Jahanbl
Jahanbl 25 days ago
We don't know if it is the board or because of the SerDes assignment.
We have the same assignment as an AU15P board, and PCIe x2 is not working on the AU15P board.
  • vmate
    vmate 25 days ago +1
    Hello, We'll need more information about what you're doing exactly, before anyone can attempt to help.
  • iksevas
    iksevas 17 days ago +1 verified
    The lanes need to be mapped appropriately! When you implement the IP, there is a check box in the last screen that allows you to map them different than the ip default. This will allow you to set the lane…
  • vmate
    0 vmate 25 days ago
  • iksevas
    +1 iksevas 17 days ago
    The lanes need to be mapped appropriately! When you implement the IP, there is a check box in the last screen that allows you to map them different than the ip default. This will allow you to set the lane constraints.
    otherwise, the ip defaults the lane settings to something different.
  • padudle
    0 padudle 10 days ago
    The AUBoard-15p looks like a good board. Yes, check the io report of your fpga design. Also, try any pre compiled example from Avnet. I like to use Linux to host the pcie fpga connection. The first command to run is lspci. In the fpga, I like to use the PCIe AXI Bridge core with DMA. It works with the Xilinx open-source XDMA driver that is easy to use. PCIe is the best way to connect an fpga to a computer. Good luck.
