Avnet Boards General AES-ALI3-AMPIRE10-G Display
  • Subscribers 372 subscribers
  • Views 435 views
  • zedboardcmty
100dkk
100dkk over 6 years ago
Is AES-ALI3-AMPIRE10-G display obsolete now ? Can I use it for a new design ?
dkk
  • zedhed
    zedhed over 6 years ago
    Hi dkk,
    We do have some example designs available targeting ZedBoard, MiniZed, PicoZed, and Zynq Mini-ITX boards, but they were all done in much older versions of the Xilinx tools:
    http://www.zedboard.org/support/design/12356/101
    Due to the overall lack of market interest in these display kits, we can no longer continue to update the display kit reference designs to newer versions of the Xilinx tools.  This kit has since been marked as End of Life and you can see there are only 4 of these left in stock as of today:
    https://www.avnet.com/shop/us/products/avnet-engineering-services/aes-ali3-ampire10-g-3074457345635221593/
    Once these are gone, there are no plans to replenish the stock on these unless someone has a need to purchase a significant amount of them at a time and we can justify doing another large production run of them.
    However, if you are planning to target an LVDS display panel in your next design then this kit does target an Ampire integrated touch display that is still in production.  So while the kit is going End of Life, the components that make up the kit are still readily available and available for new designs.  If you are targeting another LVDS panel, then this kit can also be a good platform to adapt the panel connector to one of our Zynq development boards as I have worked with several other designers who have done this as well.
    Best Regards,
    -Kevin
