Avnet Boards General Python 1300 camera
  • Subscribers 372 subscribers
  • Views 618 views
  • ZedBoard General Questions
  • zedboardcmty
Python 1300 camera
zanabonir
zanabonir over 6 years ago
Dear forum
I have the zedboard, and I would like to add a camera module,like the Python 1300. I read is compatible with microzed, but not real clear if couldbe used for zedboard also.
Thanks in advance
Roberto
  • drozwood90
    drozwood90 over 6 years ago
    Roberto,
    You would need to port the design, but the heart of the ZedBoard is similar to the MicroZed.  If you have a design like that, it would not be too hard to port over.
    --Dan
  • zanabonir
    zanabonir over 6 years ago in reply to drozwood90
    Thanks Mr Daniel for reply
    From a Electrical point of view, can I insert the camera in the zedboard connector, without
    modify or adapr the hardware (voltage ,ecc) ? I means, pin are compatible ?
    For the new design I understood...I need to modify some.
    Thanks again
    Roberto
  • drozwood90
    drozwood90 over 6 years ago in reply to zanabonir
    Hi there,
    We do not have a list of all compatible boards.  You will need to compare the schematics to be sure.  In all likelihood, it is compatible, but you will need to do your homework and check to be certain.
    --Dan
  • zanabonir
    Thanks for reply
    Colud be possible to add a IP that simulate the Python cam,so, before to connect the real hardware, I ceck if the processing chain is correct?
    Thanks again
    Roberto
