Avnet Boards General Zedboard, Spansion S25FL256S Flash Programming, FlashRead() Extra Bytes Discovered
  • Subscribers 373 subscribers
  • Views 1203 views
  • getopicszedboard_forum
go_er00
go_er00 over 5 years ago
Dear Sir:
     I wrote a simple program that writes a page of data to the Spansion flash (S25FL256S) IC on my Avnet Zedboard and then the reads this same data back for inspection.
I have attached a link below so that anyone can identify the particular Zedboard development board and the flash IC that I was referring to in my opening sentence.
ZedBoard | Avnet Boards
        I noticed that when I use the FlashRead() function provided by the Xilinx Corp. in its example programs, I read back extra bytes of data.     I have attached a "screenshot" snippet of C code in a for loop (see picture - "Flashread[] returns extra bytes").
When you look at the contents of the for loop, I write a "page" of data into the flash IC once for every loop.    The size of each "page" is 256 data entries.  Therefore, in theory, beginning with the first data entry at [0], the last data entry should be at [255].
When I read back the data that I have just written into the flash, I see extra bytes in the ReadBuffer[].    I put a breakpoint within the for loop loop to examine the contents of the ReadBuffer[] after the 1st loop and took notice of these extra bytes.
I have attached a screenshot of the ReadBuffer[] which clearly shows new data entered into the ReadBuffer[] that is highlighted in yellow after the first loop (see the "screenshot" entitled, "ReadBuffer first pass.png").
This extra data appears to be invalid data - as it has no correlation with that data that was intended to be written into the flash IC.
Can anyone tell me why I am receiving this extra data?
  • jafoste4
    jafoste4 over 5 years ago
    For support on the Zedboard please ask your question on the Digilent forum.https://forum.digilentinc.com/
    Thanks!
    Josh
  • go_er00
    go_er00 over 5 years ago in reply to jafoste4
    Thank you, Josh, for your reply.
    The question above is not necessary to pursue, it is only an academic question now.   I won't be re-posting the question as I have resolved my issue.
    Thank you for your reply.
