Avnet Boards General Yocto BSP
  • Replies 13 replies
  • Subscribers 374 subscribers
  • Views 2030 views
Yocto BSP
Is there any interest in a Yocto BSP for the zedboard? I can probably get a basic one together fairly easily, well if I can ever get a zedboard :)
    I see no reason why not ... Increasing hardware support for distro's is never a bad idea in my mind :D
    That would be great.
    Increases options and avoids the need for porting software your self. Means we should be able to use the openembedded angstrom recipes.
    Means all the python code from raspberry pii can be run on a zedboard as a step up. Only problem is the cost (for general hobbiests ).
    Still surprised no one has targeted a programmable logic kit at high schools.If someone wanted to start a project for that I'd be happy to help.
    Why does the index say there are more replies than I see here?
    I'm actually setting it up, so here's an overlay that adds support for Zedboard.
    https://github.com/milosoftware/meta-zynq
    Currently it builds u-boot and BOOT.bin (you'll need to have a FSBL binary to create BOOT.bin) and boots a rootfs from SD card.
    I am working my way through it now.  Are there any zedboard specific instructions/settings?
    Just ask if you have any questions...
    If you build "my-image" on the Zed, and (optionally) build the bitstream for the ADI framebuffer, you get a nice base image that fits in the internal flash.
    This evening I am getting git failures from Xilinx. Specifically U-Boot... Did something change.
    WARNING: Failed to fetch URL git://git.xilinx.com/u-boot-xarm.git;protocol=git, attempting MIRRORS if available
    ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
    Cloning into bare repository '/home/cah/Backup/Code/zedboard/meta-zynq/oe-core/build/downloads/git2/git.xilinx.com.u-boot-xarm.git'...
    fatal: The remote end hung up unexpectedly
    ERROR: Function failed: Fetcher failure for URL: 'git://git.xilinx.com/u-boot-xarm.git;protocol=git'. Unable to fetch URL from any source.
    ERROR: Logfile of failure stored in: /home/cah/Backup/Code/zedboard/meta-zynq/oe-core/build/tmp-eglibc/work/zynq_zc702-oe-linux-gnueabi/u-boot-zynq/xilinx-zc702-r1/temp/log.do_fetch.14282
    ERROR: Task 67 (/home/cah/Backup/Code/zedboard/meta-zynq/oe-core/meta-zynq/recipes-bsp/u-boot/u-boot-zynq_git.bb, do_fetch) failed with exit code '1'
    It is up and running again.. (for now)
    While I am here your how to has a couple of tweeks I would make
    metz-zynq -> meta-zynq
    MACHINE = "zynq-zc702 -> MACHINE ?= "zynq-zc702
    Now clone the meta-zynq layer in the oe-core directory ->
    Which oe-core directory?  You have them nested.  Can you make it more clear?
    I note your bug on BOOT.BIN and just use ISE.  Can you go through a short procedure of producing the BOOT.BIN?  If nothing else can you link to the Xilinx documentation that spells it out?
    Can you give a bit more context, I don't understand any of your questions/suggestions.
    Contact me by e-mail if you like, because it's a pain to post anything on this board, I don't visit it often...
