Avnet Boards General Vivado Licence
  • Subscribers 373 subscribers
  • Views 613 views
  • mini-module
  • minimodule
  • zynq
  • mini-module_plus
Vivado Licence
Not sure if this should go here, but....
Is the Vivado licence that the MMP comes with locked to a particular board (MMP serial number) or locked to a particular device (Z7100) so that I can purchase multiple boards (or even a different development board) and use the one licence? What is the expiration of the licence?
Craig
    Hello Craig,
    The Vivado license is locked to a device type (i.e. Z7100) and not a particular board or part.
    The Vivado license is like most of the Xilinx licenses, you are entitled to updates for 1 year, so getting your license now would get you updates through versions 2016.4 or maybe 2017.1 depending on timing. You can continue to use any of the versions you were entitled to as long as you want. So it is the ability to upgrade to the latest version that 'expires'.
    -Gary
    Licence duration is one year... as it seems to be limited in time, then how much it will cost to renew the licence?
    Sam
    Hello Sam,
    As mentioned abover the one year license duration applies only to updates. You can continue to use the tool version you are entitled to after the one year term.
    Currently the cost listed on the Xilinx website for a node locked Vivado Design Edition is $2995.00.
    http://www.xilinx.com/products/design-tools/vivado.html#buy
    If you are using a Zynq device that is a 7030 or smaller you can use the free webpack version.
    -Gary
