Avnet Boards General Problem with FMC-IMAGEON  HDMI Display Controller  Tutorial
  • Subscribers 372 subscribers
  • Views 1061 views
Hi, I am just getting started so I began with the FMC-IMAGEON  HDMI Display Controller Tutorial. I am at the bitstream generation step but I am having the following errors:
launch_runs impl_1 -to_step write_bitstream
[Ipptcl 7-5] XIT evaluation error: File writer encountered an error: c:/Xilinx/Vivado/2013.4/examples/Vivado_Tutorial/Projects/tutorial/tutorial.srcs/sources_1/bd/tutorial/ip/tutorial_axis_subset_converter_0_0/axis_subset_converter_v1_1/hdl/verilog/axis_subset_converter_v1_1_axis_subset_converter_tutorial_axis_subset_converter_0_0.v
[IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2013.4/data/ip/xilinx/axis_subset_converter_v1_1/ttcl/axis_subset_converter_v1_1_axis_subset_converter_v.xit': ERROR: [Common 17-39] 'xit::puts_ipfile' failed due to earlier errors.
[IP_Flow 19-911] XIT detected an open writer channel for file 'c:/Xilinx/Vivado/2013.4/examples/Vivado_Tutorial/Projects/tutorial/tutorial.srcs/sources_1/bd/tutorial/ip/tutorial_axis_subset_converter_0_0/axis_subset_converter_v1_1/hdl/verilog/axis_subset_converter_v1_1_axis_subset_converter_tutorial_axis_subset_converter_0_0.v'. Please use 'close_ipfile' command to close channels before exit.
[IP_Flow 19-167] Failed to deliver one or more file(s).
[IP_Flow 19-98] Generation of the IP CORE failed.
[BD 41-1030] Generation failed for the IP Integrator block /axis_subset_converter_0
Help on how to fix this is highly appreciated.
  • bhfletcher
    0 bhfletcher over 12 years ago
    Have you properly licensed the Xilinx Video and Image Processing Pack IP cores as instructed in the tutorial?
    This design uses several of the Xilinx Video and Image Processing Pack IP cores that must be licensed prior to use.
    Bryan
    0 e14 Contributor over 12 years ago in reply to bhfletcher
    I think that may be the issue, but the AXI4 Stream to Video Output and Video INput to AXI4 Stream IP cores do not show up when I browse for them on the Xilinx product licensing site.
  • bhfletcher
    Did you license the Video and Image Processing Pack?
    http://www.xilinx.com/products/intellectual-property/EF-DI-VID-IMG-IP-PACK.htm
    Bryan
