Avnet Boards General Can't install Digilent USB Device
  • Subscribers 373 subscribers
  • Views 1493 views
This is the first time to connect my Zedboard to PC.
On bord MIO6-2 are all tighed to GND and J17(PROG) is connetcted to PC by USB cable.
I'd like to program Zynq by USB-JTAG.
But PC can't find "Digilent USB Device", would you pls let me know from where I can get the driver?
    Did you select the "Install Cable Drivers" option while installing the Xilinx tools?
    -Gary
    Thanks so much for your advice.
    I have installed Vidado 2014.2 and worked well with ZYBO on this system.
    On my understanding, when I connect ZedBoard to PC, PC try to find "Digilent USB Device".
    By using Vivado, I can't find your comment.
    I was asking if you had installed the cable drivers when you initially installed the Vivado tools. If you are able to program the Zynq device on a Zybo board then you have the drivers installed on your Host PC. In that case make sure you have connected your Host PC to the J17 micro USB connector on your ZedBoard for the JTAG connection. There are two micro USB connectors on the ZedBoard. J14 on the ZedBoard is for the USB to UART connection.
    -Gary
    I have solved this problem as follows;
        Executed     C:XilinxVivado2014.2dataxicomcable_drivers
    tdigilentinstall_digilent.exe
