Avnet Boards General Can the Qorvo RF card be purchased stand alone?
  • Subscribers 373 subscribers
  • Views 988 views
  • qorvo
  • ultrascale
  • xilinx
  • sdr
  • lte
  • ultrascale+ rfsoc dev kit
  • rfsoc
mbrown
mbrown over 7 years ago
This question has already popped up several times. The answer is YES!
See the accessories section at the bottom of the UltraScale+ RFSoC Dev Kit .
  • mbrown
    mbrown over 7 years ago in reply to clem57 +1
    The kit does feature a new Qorvo device -- the QPA9903 -- an 1805 - 1880 MHz 0.5 Watt High-Efficiency Amplifier. Excellent for Digital Pre-Distortion techniques.
  • clem57
    0 clem57 over 7 years ago
    What is that?
    The Qorvo GP712 System-on-Chip is an IEEE 802.15.4 multi-stack multi-channel communications controller for integration into a ZigbeeRegistered node. It is compliant with the IEEE Standard 802.15.4, providing robust spread spectrum data communication with a secure encrypted data flow, and supports multiple ZigbeeRegistered 3.0 (including rf4ce, ZigbeeRegistered Pro and Green Power) and Thread (OpenThread https://openthread.io/platforms/gp712)  protocol stacks in the host processor. These stacks can operate in different networks (PANs) and on different channels. The GP712 is able to listen simultaneously on three different channels with antenna diversity.
    If you wondered
  • mbrown
    0 mbrown over 7 years ago in reply to clem57
    Hi Clem - the Qorvo GP712 is unrelated to the Avnet RFSoC Dev Kit. Was this meant for another forum?
  • clem57
    0 clem57 over 7 years ago in reply to mbrown
    Oh. I was taking a shot in the dark. Never mind.
  • mbrown
