Avnet Boards General PIC12F1501-E / SN Operating Temperature Issue
  • Answers 2 answers
  • Subscribers 371 subscribers
  • Views 537 views
  • ZedBoard General Questions
malugu
malugu over 6 years ago
Hello, please ask about the PIC12F1501-E / SN operating temperature:
I use PIC12F1501-E / SN as a project, input 1 PWM, 2 IO inputs, 1 ADC sampling. It works normally at normal and low temperatures. But the temperature is not too low at 80 degrees. The specific performance is:
(1) Store the sample in the ambient temperature box at 85 degrees for 30 minutes, and then power on, the MCU will not work.
(2) It can work again when the temperature is below 70 degrees.
(3) Turn on the power below 70 degrees, and it can work when the temperature is increased to 95 degrees.
This is strange. The working ambient temperature on the PIC12F1501-E / SN product data is -40 ~ + 125 ° C. Please ask, what is the problem.
This is the product data: https://www.key-components.com/parts/4D9/PIC12F1501-ESN.html
  • drozwood90
    drozwood90 over 6 years ago +1 suggested
    Hi there, Generally speaking, you should check that the REST of your board is capable of those temperatures. This forum is for Xilinx / Designed by Avnet products. You might have better luck with a forum…
    michaelkellett over 6 years ago +1 suggested
    How many samples have you tested, do they all come from the same batch ? Did you buy from a genuine Microchip distributor ? What else is in the circuit - capacitors and power suppliers can misbehave at…
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    This forum is for Xilinx / Designed by Avnet products.  You might have better luck with a forum dedicated to Microchip processors and products.
    --Dan
    0 michaelkellett over 6 years ago
    What else is in the circuit - capacitors and power suppliers can misbehave at high temperatures.
    When you can answer all these questions I suggest you contact Microchip directly.
    If you post the full circuit here I and other people may be able to spot problems - I'm very confident that Microchip wouldn't claim a part worked at 125 if it didn't, but duff parts do happen.
