Avnet Boards General Ethernet Losing UDP Packets
  • Subscribers 371 subscribers
  • Views 810 views
  • packet
  • sleep
  • ethernet
  • getopicszedboard_forum
  • udp
edharris
edharris over 6 years ago
Problem summary:
The Zedboard Tm appears to occasionally loose UDP packets across the ethernet interface.
Hardware setup:
2018.3 prebuilt binary (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57639129/Zynq+2018.3+Release)
Test setup:
A UDP packet is sent to the Zedboard every 30 seconds, and a small program keeps count of received packets.
After around 25 minutes: 50 packets sent, but only around 28 received.
If I have a ping (ICMP) running in the background to the Zedboard Tm, about 48 packets received, i.e. fewer are lost.
It is almost as if the Ethernet goes into sleep mode after a while if it’s not being actively used.
Questions:
Is this normal behaviour?
Is there a way to switch this “sleep” mode off..?
Could there be another problem I am not aware of?
  • ralphjy
    0 ralphjy over 6 years ago
    I can't answer the "sleep" mode behavior question, but if you have such low packet frequency is there a reason that you don't use TCP instead of UDP?  TCP has handshaking to prevent packet loss but UDP does not.
