Avnet Boards General Ultrazed 3EG - display port reference design - desktop linux?
  • Subscribers 373 subscribers
  • Views 1076 views
  • Software Application Development
  • Ultrazed Hardware Design
laurencebarker
laurencebarker over 6 years ago
I've found the displayport reference design for the ultrazed EG I/O carrier.
Where I want to get to is: I have desktop Linux running on the ultrazed with a monitor connected to the displayport. I've seen there is a reference design for the ZCU102, but I can't see one for the ultrazed.
Is that a simple step from the reference design, a complicated step, or is it just not viable please?
Laurence Barker
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    I'm not sure what you are asking.  Could you be more specific on what your desire is?
    --Dan
  • laurencebarker
    0 laurencebarker over 6 years ago in reply to drozwood90
    I'm trying to reach the point where the ultrazed is like a standalone computer that happens to have an FPGA. It would have a monitor attached to the displayport connection; it would have mouse and keyboard attached. It would run a desktop version of Linux with GUI etc.
    The reason I want this is: I will then also be interfacing HF software defined radio with attached ADC, DAC and digital processing in the FPGA. The user interface runs as a Linux application and presents its display to the GUI. I understand very well the signal processing and how to implement in in the FPGA; I don't know much about configuring Linux systems!
    I had previously looked at Zynq7020 based boards and one did have a port of desktop Linux with all the appropriate device drivers. I want to answer the same question for newer, Ultrascale SOM boards. I can see that a frame buffer with for example the rotating cube is possible; what I'm trying to find out is how big a step it is to having the desktop GUI form of Linux. It may be a case of simply selecting the right drivers, or it could be much more complicated!
  • narrucmot
    0 narrucmot over 6 years ago in reply to laurencebarker
    Hi Laurence,
    Currently the only board we have a Linux OS image for that does what you describe (Linux windowed desktop environment with DisplayPort output and mouse/keyboard input) is the Ultra96-V2.  This board is similar to the UltraZed-EG in that they both use the Xilinx Zu+ 3EG MPSoC device, have USB input, and DisplayPort output.  It is certainly possible to leverage the PetaLinux BSP for the Ultra96-V2 to create what you want for the UltraZed-EG.  Much of this task is probably straightforward, but this is isn't something we have or can support right now.
    --Tom
  • laurencebarker
    0 laurencebarker over 6 years ago in reply to narrucmot
    Thank you - that was exactly the information I was looking for.
    I can look at whether the Ultra96 driver set could move across to the Ultrazed. I can see there are some differences in devices but that gives me a solid start. And potentially I could use an Ultra96 for a prototype for my application: it doesn't have enough I/O connections for the final version but I can de-risk much of the project.
  • drozwood90
    0 drozwood90 over 6 years ago in reply to laurencebarker
    Hi there,
    I wanted to let you know that we are currently uploading the images for the UltraZed-EG platforms for 2019.2.  These support Vitis and have displayport with ethernet working.  Look for them on the product pages, and expect them to be there within a day or two.
    --Dan
