Avnet Boards General Re-initialize USB connection using an interrupt handler
  • Subscribers 372 subscribers
  • Views 788 views
  • MicroZed Industrial IoT Starter Kit
  • Software Application Development
  • zedboardcmty
silverwhale
silverwhale over 6 years ago
Dear Forum-members,
I am not sur where to post this question so I chose to first post it here.
I use the microZed as a USB-Device, the microzed itself is programmed to act as controller for a drive.
Now it oftne happens that the USB-connection between the microZed and the PC-Card it is connected to crashes. We do not know the cause of these crashes but my idea was to implement an interrupt handler to execute some code to restart the USB-controller whenver a crash occurs.
Now, there is in the xilinx code the following function:
void xusb_cdc_irq_handler(void *callback_ref, u32 mask);
my idea is to populate it with a
XUsbPs_Start(usb);
to restart the USB-controller whenever a crash occurs. Now, does this make sense? Or doe I need more code, to make it work?
Thanks for your help in advance!
Sincerely yours
Silverwhale
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    Are you working with the Xilinx USB controller?
    It seems so, and if so, you might have better luck getting a proper response from Xilinx on their forums as that is supported by Xilinx directly.
    --Dan
  • silverwhale
    0 silverwhale over 6 years ago in reply to drozwood90
    Thank your for your quick response.
    Yes it is the case. I will post the question in the xilinx forums then.
    Thanks again.
    Sincerely
    Silverwhale
