Avnet Boards General What is the equivalent resistance to the hottest component on the picozed PicoZed 7010/7020 SOM?
  • Subscribers 372 subscribers
  • Views 606 views
  • Zynq Mini-ITX Hardware Design
  • PicoZed Hardware Design
  • Zynq Mini-Module Plus (MMP) Hardware Design
  • PicoZed SDR Software-Defined Radio
frbeck
frbeck over 6 years ago
What is the equivalent resistance to the hottest component on the PicoZed 7010/7020 SOM? I believe this is the ZYNQ component. image
  • drozwood90
    drozwood90 over 6 years ago +1 suggested
    Hi there, I do not think you can use an R load to simulate the PicoZed's Zynq-7000. The Zynq is a dynamic load, so even if I could provide you an answer, it still depends on what you are running on the…
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    The Zynq is a dynamic load, so even if I could provide you an answer, it still depends on what you are running on the chip.  The different programs, PL loads, etc. all have an influence on the thermal output from the chip.
    --Dan
  • frbeck
    0 frbeck over 6 years ago in reply to drozwood90
    Ok. Can you tell me the material of the PicoZed board? And the amount of copper that's there?
  • drozwood90
    0 drozwood90 over 6 years ago in reply to frbeck
    Hi there,
    For details like that, you would need to contact your local FAE.  They can request factory details like that on your behalf.
    --Dan
