Avnet Boards General Zedboard 7Z020, stopped working? (no power LED)
  • Subscribers 371 subscribers
  • Views 568 views
  • ZedBoard General Questions
  • Zedboard Hardware Design
  • Zedboard Training
  • zedboardcmty
jroo
jroo over 5 years ago
I've been running a Zedboard for several weeks, and just noticed it stopped running. It is powered by the 12V 3A barrel connector and those points show 12V. Switching off and switching back on, the green power LED isn't lighted. I do not have any external accessories connected, so there shouldn't be any unusual electrical loads. Has anyone else had this issue? Is there any regulator/fuse I should probe to check if a part has failed?
Thanks!
  • drozwood90
    0 drozwood90 over 5 years ago
    HI there,
    You can take a look at the schematics on the Technical Documents tab of the product page to see if you see something -
    ZedBoard
    Are you following proper ESD handling of your board?
    You might have better luck asking this question over at the Digilent forums where people are actively engaged in using this board.
    --Dan
