Avnet Boards General How Can I reload the original demo program/FPGA configuration that came installed on my MiniZed board?
  • Subscribers 372 subscribers
  • Views 777 views
  • Using Xilinx Tools
  • ZedBoard General Questions
  • Software Application Development
  • MiniZed Hardware Design
  • Zedboard Training
  • zedboardcmty
tmiller652
tmiller652 over 5 years ago
Does anyone know where I would find the original bitstream and demo code that came pre-installed on the MiniZed board?
Thanks in advance for the help and best regards,
Tom Miller
  • drozwood90
    drozwood90 over 5 years ago +1 verified
    Hi there, If you head over to the product page: MiniZed Click on the "Technical Documents" tab, then search for "Restore QSPI and eMMC Factory Images" You should be all set! --Dan
  • drozwood90
    drozwood90 over 5 years ago in reply to tmiller652 +1
    HI there, The documentation seems to talk about v2017.1. If you head to the Reference Designs Tab on the same product page MiniZed At the bottom, you will see the "PetaLinux Board Support Packages" section…
  • drozwood90
    0 drozwood90 over 5 years ago
    Hi there,
    MiniZed
    --Dan
  • tmiller652
    0 tmiller652 over 5 years ago
    Thanks for the reply Dan!  Do you know if the source hardware design and software are available for inspection? It would be kind of cool to be able to see the block diagram of the hardware design.
  • drozwood90
    0 drozwood90 over 5 years ago in reply to tmiller652
    HI there,
    MiniZed
    At the bottom, you will see the "PetaLinux Board Support Packages" section.
    Without doing a MD5 I can't be certain it is the exact same image, but the 2017.1 BSP should be nearly identical.  Note there are two images.  One that is "large" and one that is "small".  I believe the factory image should be the large one.
    --Dan
