Avnet Boards General How to prevent copy/cloning of exe file in the SD card?
  • Answers 3 answers
  • Subscribers 372 subscribers
  • Views 1631 views
  • Using Xilinx Tools
  • ZedBoard General Questions
  • Zedboard Hardware Design
  • Software Application Development
  • PicoZed SDR Software-Defined Radio
  • Zedboard Training
  • zedboardcmty
manoj_loka
manoj_loka over 5 years ago
We are using a Zedboard with an FMCOMMS3 ( from analog devices) for a detector system. The executable file for standalone mode is in the SD card of the Zedboard. We are planning to send the detector for customer trials and evaluation.
How do we prevent someone from copying/cloning the exe file from the SD card?
Is there any unique hardware ID ( either zedboard or FMCOMMS 3 board ) that can be used for verification?
Thank you and hope to hear some suggestions.
Manoj
    Jan Cumps over 5 years ago +2 suggested
    The AES-PMOD-TPM20-SLB9670-G Trusted Platform Module plugin, made for Zynq . This allows you to deploy several check mechanisms. One option is that you embed the endorsement key of the TPM in the executable…
    Jan Cumps over 5 years ago in reply to manoj_loka +1 suggested
    To see how functionality is executed, I check the integration test set of the tpm2 github. https://github.com/tpm2-software/tpm2-tools Here is a proposed step guide: https://stackoverflow.com/questions…
  • manoj_loka
    manoj_loka over 5 years ago in reply to Jan Cumps +1
    Hi Jan Cumps, Thank you very much. Let me try and see how it goes. Manoj
    0 Jan Cumps over 5 years ago
    This allows you to deploy several check mechanisms. One option is that you embed the endorsement key of the TPM in the executable and use the linux TPM libraries to authenticate before proceeding with execution.
    That way, one binary will only run on the hardware that has that particular unique  TPM ic plugged in.
    It also allows for trusted boot, where the device would only accept images signed by you...
  • manoj_loka
    0 manoj_loka over 5 years ago in reply to Jan Cumps
    Hi Jan Cumps,
    Thank you very much for your reply.
    I think this is the device that I was looking for. Let me buy one unit and try.
    Thanks again...
    Manoj
  • manoj_loka
    Hi Jan Cumps,
    I have already bought the module and plan to integrate it with the Zedboard soon. As a beginner, my skills are very limited in this field. It would be great if you can suggest any document or link which can guide me in the integration. Thank you in advance.
    Manoj
    0 Jan Cumps over 5 years ago in reply to manoj_loka
    Here is a proposed step guide: https://stackoverflow.com/questions/9117772/how-do-you-implement-a-platform-license-dongle-with-tpm-on-linux
  • manoj_loka
    Hi Jan Cumps,
    Manoj
    0 Jan Cumps over 4 years ago in reply to manoj_loka
    There is a roadtest for this IC now: Infineon Trust Platform Module + Raspberry Pi 3 B
