Avnet Boards General IPI configuration on a UltraScale+ ZCU106 board
  • Subscribers 372 subscribers
  • Views 2021 views
rossierd
rossierd over 4 years ago
I have a very specific question about the IPI (Inter-Processor-Interrupt) at the Cortex-A53 level using Linux.
Actually, we are working on a framework called OpenCN which is a system control with embedded path planning algorithms and hard realtime control
and currently porting on a ZCU106 board. The framework is based on a patched Linux 5.10 with asymmetric multi-processing.
In this context, we need to use IPI 8 and 9 which are not used by Linux. The problem is that only IPI 0-7 are recognized by the GIC at the moment
(they seem not to be activated somehow...). The issue is also reported there : https://discourse.heig-vd.ch/t/porting-opencn-on-ultra-scale-zcu106/248/2
(thanks if you can follow the discussion there as well :-))
Thanks for any input.
  • cstanton
    0 cstanton over 4 years ago
    Moved to Avnet & Tria Boards Community, Feedback and Support is for element14 Community support.
    Make sure you click to join the group.
    /members-area/support/w/site-faq/27370/why-can-t-i-create-content-or-comment
  • narrucmot
    0 narrucmot over 4 years ago
    This question would be better asked on the Xilinx forums.  Perhaps this forum thread will help?
    https://support.xilinx.com/s/question/0D52E00006hpte9SAA/apu-to-pl-inter-process-interrupt
    --Tom
