Avnet Boards General Question about bootloader in "SPI SREC Bootloader Example Design for the Arty Evaluation Board"
  • Subscribers 373 subscribers
  • Views 1422 views
ischoi
ischoi over 4 years ago
Dear AVNET.
I have a question about your product.
* Product reference)
www.avnet.com/.../UG-AES-A7MB-7A35T-G-Arty-SREC-Bootloader-VIV2015-2-V1.pdf
"LIT# 5185-7A35T-Arty-SREC-Bootloader-VIV2015-2-V1"
Question #1)
In the above PDF datasheet at 10.2 (page 50), "10.2 Program the QSPI Flash Using the SDK".
Is the bootloader "SREC Bootloader" or "SREC SPI Bootloader" ?
In "9.3.4 Description of QSPI SREC Bootloader Source Code Edits". "SREC SPI Bootloader" is used.
But, In 10.2 (page 50), "10.2 Program the QSPI Flash Using the SDK", "SREC Bootloader" seems to be used.
Would let me know the bootloader at "10.2 (page 50)" whether it is "SREC Bootloader" or "SREC SPI Bootloader" ?
It is important for me.
I will really appreciate if I can be given answer.
Thank you very much.
Ick-Sung Choi.
    shabaz over 4 years ago +1 verified
    Hi, Not that I'm knowledgeable on this platform, but it's the same thing I think? It's just terminology. You can call it whatever, it's still a bootloader that uses S-record format, decodes that, and…
    +1 shabaz over 4 years ago
    Not that I'm knowledgeable on this platform, but it's the same thing I think? It's just terminology. You can call it whatever, it's still a bootloader that uses S-record format, decodes that, and programs the storage device over SPI.
  • jafoste4
    0 jafoste4 over 4 years ago
    Your best bet is to ask this question over at the Digilent forum
    https://forum.digilent.com/
    -Josh
  • ischoi
    0 ischoi over 4 years ago in reply to shabaz
    Thank you for your answer.
    The configuration flash is connected using SPI interface.
    And the "SREC Bootloader" uses BPI interface.
    It is the problem.
    Thank you.
  • ischoi
    0 ischoi over 4 years ago in reply to jafoste4
