MaaXBoard Hardware Design Enabling USB Gadget on Yocto
  • Subscribers 358 subscribers
  • Views 1532 views
Mike-YYC
Mike-YYC over 2 years ago
Has anyone had any success in enabling USB Gadget device support on USB0 as outlined in section 3.10.2 USB Device of the Yocto User Manual V2.1?
I have tried a few different iterations and I cannot seem to get USB Device mode started.
Also, the example provided in manual is using the USB0 in device mode as a USB Serial device. We would like to use for other types of Gadgets. Is this supported?
  • Mike-YYC
    So I figured it out - took looking back in some history of kernel releases where there was more comments in uEnv.txt file saying how to configure / use different modes. All do not match documentation.
    To enable USB0 in Device mode you need to update your uEnv.txt in uBoot directory and uncomment following line:
    #fdt_file=maaxboard-usb0-device.dtb
    After reboot, Gadget works as expected. At least in my initial testing.
  • Mike-YYC
    Mike-YYC over 2 years ago in reply to Mike-YYC
    Actually, the section 3.1 Settings in uEnv.txt shows a copy of uEnv.txt with full documentation. What is needed is an update to section 3.10.2 - it is misleading.
