MaaXBoard Hardware Design Maaxboard-rt parallel camera
  • Subscribers 358 subscribers
  • Views 677 views
  • csi
  • parallel interface
  • MaaXBoard-RT
  • schematics
  • camera
  • pinout
zohargolan
zohargolan over 1 year ago
Hi all,
I need to connect a parallel CSI camera to the Maaxboard-RT and I cannot find schematics or the pinout for the Raspberry-PI connectors. Is there an app note or a project using a parallel camera?
Thank you for your help,
Zohar
  • jc2048
    0 jc2048 over 1 year ago
    I'm just a random engineer passing by, so apologies if I'm not really understanding this.
    Are you interested in the camera side of the interface or the board side? The schematics for the various Pi cameras are published on their website. If you are sure that the Maaxboard-RT CSI connector is compatible with the Pi cameras (very possible, as it's a good design decision with so many cameras readily available for that pin-out; though the short-form that is the only hardware info directly available on the Tria website doesn't actually say that it is), then doesn't that give you enough info for getting other image sensors with a CSI-MIPI interface connected?
    On the board side, the CSI-MIPI connects to a dedicated interface on the processor, so can't you get all you need for that from NXP support material for the processor?
    From watching replies to other Avnet board queries, it seems to me that they are always reluctant to hand out detailed hardware information and often suggest speaking to an FAE for your area to obtain information (presumably under NDA), so you might find that route quicker than hoping for a reply here.
  • zohargolan
    0 zohargolan over 1 year ago
    Thank you jc2048 ,
    I am actually looking at connecting to parallel CSI and not MIPI CSI camera. For that I need to use the FlexIO pins from the RT1176. Withou the schematics, I cannot see what pins are connected from the PI connector to the RT1176.
    I guess you are right about contacting the FAE. Was hoping to get pointers in here though
    Zohar
