MicroZed Hardware Design Net lengths and clocking pins
  • Subscribers 361 subscribers
  • Views 421 views
I am designing a carrier board for microzed that will interface an ADC. It has an 8 wire LVDS interface and timing is quite critical.
I am trying to confirm which pins on the JX headers correspond to the MRCC and SRCC capable pairs. The pinout in the Altium librtary does not explicitly specify...
I have found the spreadsheet with the net lengths which is great, but can I confirm that for example:
JX1_LVDS_11_P connects to IO_L11P_T1_SRCC_35 on the chip.
Many thanks in advance!
Ben.
    Actually JX1_LVDS_11_P is connected to IO_L12P_T1_MRCC_34 (Zynq package pin U18).
    ( I know, the MicroZed JX LVDS pair numbers do not match up with the Xilinx signal pair number names ).
    You can verify this using the MicroZed Schematic and/or the MicroZed Master XDC file (generated from the netlist), both found here:
    http://zedboard.org/support/documentation/1519
    -Gary
    Yikes, thanks for the fast reply! you may have saved me from embarrassment.
