MicroZed Hardware Design MicroZed daughterboard with 2nd PHY?
  • Subscribers 362 subscribers
  • Views 779 views
100kenc
100kenc over 9 years ago
I would like to use the second eth MAC in the Zync. Are there any MicroZed daughterboards available for this?
I was planning to modify this http://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/TCPIP_FAT_Examples_Xilinx_Zynq.html
for 2 ethernet ports, but I could not find Zync boards with 2 ETH PHYs. I already have 1 MicroZed board, so a daughterboard with an additional PHY connected to the second ETH MAC would be nice.
Ken
  • 100kenc
    0 100kenc over 9 years ago
    Can I use the FMC carrier board + ethernetfmc.com (quad ethernet) board for this purpose? I don't need the AXI ethernet solution, right?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Ken,
    Try taking a look at the Ethernet FMC over at this link
    http://ethernetfmc.com/exampledesigns/
    There is also an example design already done on the MicroZed to help you get started.
    --Josh
  • 100kenc
    0 100kenc over 9 years ago in reply to jafoste4
    Thanks Josh,
    I will try that.
    regards,
    Ken
  • 100kenc
    Hi Josh, I have one more question about this.
    According to the MIO table from Xilinx, I can use MIO pins 28 to 39 to connect to ETH1 if I don't need USB0. In that case I don't need to route ETH1 to EMIO pins via the PL.
    Is that correct?
    regards,
    Ken
  • jafoste4
    Hello KenC,
    Please take a look at the following post.
    https://forums.xilinx.com/t5/Xcell-Daily-Blog/Adam-Taylor-s-MicroZed-Chronicles-Part-77-Introducing-the-Zynq/ba-p/591316
    --Josh
