MicroZed Hardware Design Basic pull up tri state test trouble
  • Subscribers 361 subscribers
  • Views 801 views
smvo555
smvo555 over 10 years ago
Can  any one weigh in and let me know what's wrong with my basic example below?
I've implemented a very simple tri state example. I've copied two pieces of code below which correspond to the two different oscilliscope images in the attached picture. I constrained the inout csb as it connects on the top level in my block diagram as an internal pull up. I would expect to be able to toggle the pull up using verilog code A below but the inout port stays low for some reason. It seems like it gets stuck I'm hoping that what ever is wrong here is also the problem with my SPI interface.
This is done with a 7z010 Microzed and Vivado tools 2014.1
I don't see anywhere to attach my picture , I'll look more for the option after posting
Thanks so much,
Sam
//verilog code A
module tri_stated(
    inout csb,
    input clk,
    input reset
    reg oreg;
    assign csb = oreg;
    reg data;
    reg [15:0] count;
    wire oen;
    assign oen = count[3];
    initial oreg = 1'bz;
    always @(posedge clk)
    if(reset)begin
    count <= 16'd0;
    end else
    count <= count + 1'b1;
       always @(oen or oreg)
       if (oen == 1'b1)
          oreg = 1'd0;
       else if(oen == 1'b0)
          oreg = 1'bz;
endmodule
//Verilog code B
module tri_stated(
    inout csb,
    input clk,
    input reset
    reg oreg;
    assign csb = oreg;
    reg data;
    reg [15:0] count;
    wire oen;
    if(reset)begin
    count <= 16'd0;
    end else
       if (oen == 1'b1)
          oreg = 1'bz;
          oreg = 1'bz;
endmodule
  • smvo555
    0 smvo555 over 10 years ago
    I don't see a way to attach a picture to this message.
    You would see screen shots on the oscope of the port CSB measured after FPGA config for both code A and code B above.
    Code B goes high after config for ~150us then goes low, code B stays in a high impedance state and on the oscope you can see the port going high after configuration and staying high indefinitely
  • smvo555
    0 smvo555 over 10 years ago in reply to smvo555
    I ended up figuring out the software for some IP peripherals which were handling the tri state bus for me anyways, so I did not have to work at such a low level. Not sure how to this with a custom IP correctly but I suppose with Zynq I don't really need to
