MicroZed Hardware Design Microzed Preset TCL Files
  • Subscribers 362 subscribers
  • Views 1053 views
e14 Contributor over 8 years ago
I am attempting to create a board design using Vivado 2016.2 with a Microzed 7020 and FMC Carrier Card.
I cannot find a Preset for the ZYNQ7 Processing System.
I am using the Board Definition Files located at
http://zedboard.org/content/board-definition-files-0
but that contains a file, preset.xml which is not a valid preset since Vivado expects a TCL file.
I also tried downloading the preset : MicroZed Zynq PS Preset for Vivado 2013.4 (TCL)
but Vivado says that is not a valid preset either.
Is there a Zynq PS preset for Vivado 2016.2?
  • jafoste4
    0 jafoste4 over 8 years ago
    Did you install the BDF labeled MicroZed Board Definition Install for Vivado 2015.3 through 2017.4
    and what directory did you install it in?
    --Josh
    0 e14 Contributor over 8 years ago in reply to jafoste4
    I have the same problem. I installed the BDF labeled files for Vivado 2015 to 2017.4, but I am not able to see the microzed in the preset menu while configuring the PS. Still, I am able to see the zedboard ones.
    I triede to source the tcl script MicroZed_PS_properties_v03.tcl , but then I got an error during bitstream generation.
    What can I do to solve this?
    Andrea
  • jafoste4
    Hi Andrea,
    Please confirm you have closed and reopened Vivado after installing the new BDFs. Also what directory did you install to?
    -Josh
