MicroZed Hardware Design Beginner, need help understanding the breakout carrier board
  • Subscribers 362 subscribers
  • Views 891 views
souyu
souyu over 8 years ago
Hi, I have recently got into the Microzed due to a project at school, and I am quite lost.
I have experience with Verilog using the Nexys4 FPGA board, and that seem much simpler than the Microzed.
I was able to run a Hello World program through the SDK to the Microzed, and now I wish to use the Breakout Carrier Board for the programmable logics,but I don't understand how to access the Carrier Board, and I was not able to find any instructions or tutorial online about it.
If anyone can send me in the right directions, I would be grateful.
  • jafoste4
    0 jafoste4 over 8 years ago
    The carrier board just sends all the extra IO out so it accessible to you. You  can then solder on whatever circuit you want to your carrier card to perform you desired application. It does none of the programmable logic.
    All the programmable logic is done by the zynq device on the MicroZed.
    --Josh
  • souyu
    0 souyu over 8 years ago
    Okay, so how can I program the zynq to use these IO?
  • jafoste4
    You develop your hardware image in Vivado and then using constaints Map whatever IO to the IO carrier care you want.
    --Josh
  • souyu
    Okay, it sounds familiar as the Nexys. However, I noticed that the Microzed does not have a built in clock, and you have to create it from the PS side. How would I connect the PS to the PL in verilog?
  • jafoste4
    Hello Souyu,
    I would utilize the built in customizable PL clocks in the Zynq. You would add the zynq device into the block diagram and then enable the PL clocks in the zynq clock customization window. For more information please take our develpoing zynq hardware speedway course. It covers all the basics of a Zynq design.
    http://zedboard.org/support/trainings-and-videos
    --Josh
