MicroZed Hardware Design MicroZed DK - AES-Z7MB-7Z010-G + Proximity Sensor
  • Subscribers 362 subscribers
  • Views 1022 views
  • microzed
  • proximity sensor
  • fpga
  • proximity sensors
andcre-avnet
andcre-avnet over 7 years ago
We developed a project with the MicroZed Development Kit - AES-Z7MB-7Z010-G
I would need a proximity sensor (equivalent to Maxim's "MAX44000PMB1" sensor) compatible with the board listed above.
Attached the documentation we used to start the project using the MAX44000PMB1 sensor.
Do you know if there is a list of proximity sensors compatible with the MicroZed ?
Plus can you point me to a proximity sensor equivalent to the MAX44000PMB1 ?
Thanks in advance,
Andrea
image09_MZPZ_PL_I2C_PMOD_2016_4_01.pdf
  • jafoste4
    jafoste4 over 7 years ago +1
    Hi, Mind me asking what the issue is with the MAX44000PMB1 sensor PMOD? If you change sensors it will require a significant amount of application code rework and understanding of the sensor. It won't be…
  • jafoste4
    jafoste4 over 7 years ago in reply to andcre-avnet +1
    I was unaware of the EOL. thanks for sharing! If you get a chance, please share your findings on other sensors! Thanks, Josh
  • jafoste4
    If you change sensors it will require a significant amount of application code rework and understanding of the sensor. It won't be plug and play with what you currently have.
    Digilent offers a fair amount of PMODs that you can take a look at.
    -Josh
  • andcre-avnet
    andcre-avnet over 7 years ago in reply to jafoste4
    Hello Joshua,
    thanks for the reply.
    The main problem is that the MAX44000 is going to be obsolete really soon (PCN already sent by Maxim).
    So i need another one at least similar.
    Thanks for the suggestion about the Digilent.
    If you have any other info or suggestion feel free to tell me.
    Best regards,
    Andrea
  • jafoste4
    Josh
