Mini-ITX Hardware Design help me  with  usb hub problem
  • Subscribers 354 subscribers
  • Views 791 views
In my board there is a usb hub device connected to the zynq PS usb controller, just like the mini-itx  board.
The issue confused meis that when running the linux kernel(3.14), it can not find the usb hub device, just prinf words like this:
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
when i input "lsusb" i can see "Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ",but there should be usb hub device uunder root hub.
who can help me?
    Just to be clear, are you using a Mini-ITX board or some other Zynq based board?
    If it is a Mini-ITX board which version are you using?
    -Gary
    thanks for your apply.
    I used a zynq based board.
    now the problem is
    "usb 1-1: new high-speed USB device number 2 using
    zynq-ehci
    usb 1-1: device not accepting address 2, error -71".
    is it caused by the hardware?
    problem is solved .
    Partner put a wrong crystal in the usb3320 side
