Mini-ITX Hardware Design PCIe addressing in Mini-ITX
  • Subscribers 354 subscribers
  • Views 522 views
I ahve a question about PCIe addressing in Mini-ITX.
Dose Mini-ITX support Large Block addressing for PCIe devices (larger than 4GB window)?
    In short, the answer is yes. The PCIe IP must be configured to support 64-bit addressing on the Endpoint device as well the Root Port running on the Mini-ITX board. The OS running on the Mini-ITX must support 64-bit addressing as well.
    Thank you,
    Is FPGA of ZYNQ in Mini-ITX (7Z100 SoC) is big enough to have a PCIe IP with 64-bit addressing, addressing larger than 4GB window and in Root complex mode?
    I need to keep resource of FPGA for other tasks too.
