MiniZed Hardware Design Could anyone help me get started with minized ?
  • Replies 7 replies
  • Subscribers 362 subscribers
  • Views 1307 views
  • minized
matgoszcz
matgoszcz over 6 years ago
first of all, I would like to be able to upload programs written in vhdl.
I don't know how to create correct constraints file.
Thanks for the help in advance
  • Fred27
    Fred27 over 6 years ago
    The first Path to Programmable is a good resource to see how others got on. The course they were following is available as Avnet Speedway which you can download and follow for free. (registration on the Avnet site is required.)
  • matgoszcz
    matgoszcz over 6 years ago in reply to Fred27
    Which one will it be ?
  • Fred27
    Fred27 over 6 years ago in reply to matgoszcz
    The first two.
  • bartokon
    bartokon over 6 years ago
    Hi, do you know what default file system eMMC has?. I want to read image.ub from eMMC but it says that it can't read file system.
  • clem57
    clem57 over 6 years ago in reply to bartokon
    Did you do the read under root?
    Clem
  • narrucmot
    narrucmot over 6 years ago in reply to bartokon
    If the MiniZed is brand new and the eMMC has never been used, it will need to be partitioned and formatted.  The PetaLinux BSPs provided by Avnet for the MiniZed include a shell script (format_emmc.sh) to create and format a small (128MB) DOS partition.
    The PetaLinux BSPs for MiniZed can be found here:
    MiniZed
    The shell script looks like this:
    #Delete partition and add a new one of 128MB
    echo "fdisk /dev/mmcblk1 (1 partition of 128MB)"
    echo -e "d
    o
    n
    p
    1
    1
    +128M
    w
    " | fdisk /dev/mmcblk1
    echo "sleep 1"
    sleep 1
    #Format as a DOS partition
    echo "mkdosfs -F 32 /dev/mmcblk1p1"
    echo "sleep 1"
    sleep 1
    #Mount eMMC
    echo "/dev/mmcblk1p1 /mnt"
    mount /dev/mmcblk1p1 /mnt
    echo "ls -l /mnt"
    ls -l /mnt
    #Unmount drive again:
    echo "umount /mnt"
    umount /mnt
    NOTE!  You may want to use fdisk first to verify the eMMC is indeed empty.  Creating a new partition table and formatting a new partition will destroy any data already on the eMMC.
    --Tom
  • bartokon
    bartokon over 6 years ago in reply to narrucmot
    Thank you, Tom!
    I have managed to run my minized (again) on Petalinux 2019.2. I just have one more question, do you know what petalinux package is required to have "mkdosfs"?.
    I bypassed this issue by flash programming with minimal bootable version from restoring minized tutorial but still I would like to know.
    Thanks.
